Just Did The Heater Core....
Old Nov 26, 2004 | 01:31 PM
black84z28-4spd's Avatar
you know...i was scared at first because of all the talk on these boards about how much of a pain in the butt it was...i got mine in and hour in little over an hour...my first time!
just gotta finish up the wiring and plumbing, fill with fluids and all done!
if i haven't mentioned before the previous owner pulled out all the heating equipment, i am putting it back in
lucky me he was nice enough not to hack up the wiring harness!, the hard part is getting the damn thing back in!
Old Nov 26, 2004 | 01:55 PM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
Early 3rdgens heater cores are very easy to replace. It only took me a half an hour to replace mine. Only needed a couple srew drivers and a wobble driver. We wont mention the upper screw which was "factory deleted"
Old Nov 26, 2004 | 02:46 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
HAHA so true....oh oops....shhhh
Old Nov 26, 2004 | 11:08 PM
EvilCartman's Avatar
Car: '82 Z28
What upper screw? Just did my heater core last week, pretty easy job.
Old Nov 27, 2004 | 03:01 AM
RSFreak's Avatar
Car: 1985 Camaro, 1986 Trans Am
Engine: 5.0L carbed and 5.0L TPI
Transmission: TH700R4
Axle/Gears: 3.23 and 3.27 posi
I gotta do my heater core soon, before it gets too cold. What all is involved? What wiring were you refering to? My car is an '84 Z28.
Old Nov 27, 2004 | 04:34 AM
what i am talking about is the wiring for the ac and blower motor, the previous owner took everything out
its not all that bad...just gotta have some patience and time,
i also did the screw deletes
Old Nov 27, 2004 | 06:59 AM
AJ_92RS's Avatar
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
Not so easy on the newer cars.
Mine took me and a friend ~4hrs.
Old Nov 27, 2004 | 08:34 AM
John Millican's Avatar
Car: 1997 Jeep Wrangler
Engine: 4.0L
Transmission: 5 speed
Axle/Gears: 8.8 rear, 4.56 gears, 4:1 transfer
It all depends on the vehicle. Lots of cars require total removal of the dash. Some are easy too. I consider the 3rd gen to be one of the easiest heater core vehicles out there. All you need is a 7mm socket and a few different length extensions. Here's a great guide.
http://www.hioutput.com/tech/heatercore.html
Old Nov 28, 2004 | 04:17 PM
AJ_92RS's Avatar
By "newer" I meant my '92 RS. :shrug:
Old Nov 28, 2004 | 07:19 PM
Engine: 4.0L
I highly doubt that a '92 RS would require total removal of the dash. I would say it's exactly like any other 3rd gen and a 7mm socket would do the trick just like the link i posted.
Old Nov 28, 2004 | 07:38 PM
AJ_92RS's Avatar
Yea. You're right. I'm lying.
Old Nov 28, 2004 | 07:41 PM
AJ_92RS's Avatar
DP
Formula8r89
Sep 22, 2015 04:24 PM
BWilcox
Sep 20, 2015 12:19 PM
