87 305 main caps on an 89 350
Old Nov 26, 2004 | 03:56 PM
84camz28's Avatar
Car: 1988 IROC-Z/1996 DODGE RAM 1500
Engine: 350 L98 TPI/360 v8
Transmission: 700r4/46RE 4x4
Axle/Gears: 4th gen 3.42 10 Bolt Posi/3.90 posi
can you put the main caps off of an 87 305 with a one piece seal onto an 89 350 with a one piece thanks
Old Nov 26, 2004 | 04:12 PM
ME Leigh's Avatar
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
Yes but it will cost more in machine work then it would be just to find a new block.
Old Nov 26, 2004 | 04:19 PM
84camz28's Avatar
yeah i just found the block and crank but would it be better just to convert the 2 bolt mains to a 4 bolt. i am only missing 3 caps on the 350
Old Nov 26, 2004 | 04:40 PM
ME Leigh's Avatar
Car: 82 Z28
Transmission: TH350
It would be better to find a complete block with correct matching caps. You could always convert to splayed 4-bolt($150 for caps), but theres more money for the caps. Its the same cost no matter what caps you use for machine work.
Driven on the street though it doesn't matter how many bolt caps you have.
Jake_92RS
Jan 28, 2020 10:37 PM
Reborn756
Sep 4, 2015 03:42 AM
theurge
Aug 21, 2015 12:46 PM
st.evel07
Aug 13, 2015 06:15 PM
