which plugs to use
Old Nov 27, 2004 | 01:22 AM
JOHNCOO5's Avatar
Car: 85 IROC-Z
Engine: 5.0 TPI
which plugs to use
I just did an '85 870 ecm to '87 165 ecm swap, don't know what plugs to use.
The 85 5.0 tpi called for R43TS and the 87 5.0 tpi called for R45TS, don't know if the difference is in the motor or the electronics between the two years?
Any suggestions will help.
Old Nov 27, 2004 | 03:07 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Heat range is typically determined by head cooling design and compression ratio.
Since both the heads and compression ratio changed in 1987, that's the best explanation for the plug change. I'd stick with the plugs recommended for the engine.
Old Nov 28, 2004 | 07:59 PM
JOHNCOO5's Avatar
Car: 85 IROC-Z
Engine: 5.0 TPI
much appreciated.
wigmobile
Feb 26, 2025 02:56 PM
gta892000
Aug 11, 2019 11:16 AM
92rsvortec350
Sep 10, 2015 10:54 AM
Jlanz55
Sep 9, 2015 09:09 AM
89 formula TPI
Sep 7, 2015 11:06 AM
