UGLY noise!
Old Dec 1, 2004 | 05:31 AM
sr.bond's Avatar
Car: 1982-z-28.1987 sc
Engine: 350 on z-28,305 on sc
Transmission: bw t-10 on z-28,700r4 on sc
UGLY noise!
hi guys,i've been having this stinkin noise in my car lately and its gettin worse,its similar to a rod knocking but it seems to come from the tranny,i searched the forums and i found that there is something about the tq converter bolts going loose,do you guys have any more suggestions?thanks in advance
Old Dec 1, 2004 | 06:13 AM
kevinc's Avatar
Car: 1982 Z28
Re: UGLY noise!
I worked on a car w/ that type of noise, the cause was the bellhousing bolts were loose. I checked his TC bolts and they were fine, so we just removed/cleaned/reinstalled his bellhousing bolts with a dab of Loctite blue and no more noise.
Old Dec 1, 2004 | 08:48 AM
BIGJON's Avatar
Car: 1989 Formula 350 Firebird
Transmission: 700 R4
BELL HOUSING!!! Seriously.... I thought is was distributer noise or TC noise but after about a month of that I FINALLY found out what it was when I started having tranny trouble...
Old Dec 1, 2004 | 09:04 AM
mystikkal_69's Avatar
Car: 1988 IROC-Z
Engine: L98 (350 TPI)
Transmission: MD8 (700 R4) + 3.42 LS1 Rear
i've you have driven long enough with the bellhousing to engine bolts loose, the flywheel will crack. the same thing happened to a friends firebird.
check those along with the TC bolts. good luck.
Old Dec 2, 2004 | 03:12 AM
sr.bond's Avatar
thanks guys,i'll check those asap!
Old Dec 3, 2004 | 05:32 PM
JP86SS's Avatar
Car: 86 Monte SS (730,$8D,G3,AP,4K,S_V4)
Engine: 406 Hyd Roller 236/242
Transmission: 700R4 HomeBrew, 2.4K stall
Axle/Gears: 3:73 Posi, 7.5 Soon to break
I never would have believed it, but It happened to me too!
I thought the flywheel had broken off but it was just loose bolts. Severly loose to the point the trans was moving 1/4".
Jp
Old Dec 5, 2004 | 06:18 PM
sellmanb's Avatar
Car: '86 Berlinetta
any update on this?
Old Dec 8, 2004 | 02:05 AM
sr.bond's Avatar
it turned out to be the tq.converter bolts,thanks a lot guys
MoJoe
Members Camaros
33
Feb 6, 2025 09:47 PM
db057
Jan 10, 2020 08:55 PM
Elephantismo
Feb 13, 2019 12:51 AM
sleprock
Interior Parts Wanted
Oct 3, 2015 11:01 PM
sjorgens
Oct 1, 2015 07:54 PM
