Crazy engine vibration.
Old Jun 4, 2001 | 10:07 AM
brockrodgers's Avatar
Car: YTG Camaro
Engine: 383
Transmission: TH-350
I have unbolted the torqe convertor and moved it back from the fly wheel and it still vibrates. I visually looked at the harmonic balancer and it does not seem to be out of wack. I don't know if it is worth my time and effort to change the flw wheel at least it give me an excuse to by a higher stall torque converter. It is a small block and I have the understanding that this block should be an internalley balanced engine.
The problem has always been there but I thought it was a bent rim. Ever since I have put new rims and a PU trans mount I have noticed it more because it is stiffer.
Anybody have any adice that would either give me the kick in the rear to start digging in or direct me toward something else that could potentially be the true root cause?
'84 Camaro w/ Large Jouranl 327 bored .030 over; 3.73 geared Auburn Limited Slip Diff. FlowMaster Muffler w/ Shortie Headers. TH-350 Built Trany Underneath B Mega-Shifter. Many Engine compartment Dress Up Mods. Edelbrock High Flow Water Pump w/ Flex-a-Lite Cooling Fan.
Work in progress is Sponh Torque Arm just installed working towards 2400 stall convertor. www.chartermi.net~brodgers
Old Jun 6, 2001 | 12:59 AM
Z-83's Avatar
Is it only vibrating when you're moving? If it vibrates at idle it could be a vacuum leak, my engine used to vibrate like crazy at idle. I replaced the gasket between the carb and intake and now it's nice and smooth.
'83 Z28
305 4bbl
TH-700R4
3.23 posi (ok, L/S)
no mods... yet
Old Jun 6, 2001 | 07:04 AM
Car: YTG Camaro
Engine: 383
No I does not only vibrate when moving. I can feel it with the TC off and engine at apx 2500 parked.
Old Jun 6, 2001 | 04:23 PM
BenIroc's Avatar
I have almost the same problem with my 89 Iroc, but the vibration comes at 4300 rpm.
Anyway I retarded the ignition a bit and the vibration got a lot softer. You could try to
retard your ignition a little and se if it gets better.
Good luck
Ben
Azrael91966669
25
Jun 20, 2017 04:04 AM
Fronzizzle
Aug 19, 2015 01:36 PM
kyleb24
Aug 15, 2015 08:24 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
matthew911
Aug 12, 2015 09:38 AM
