Engine stalls after i stop...
Old Dec 2, 2004 | 07:53 AM
therckid's Avatar
Car: 1986 Trans Am
Engine: 305 LB9 TPI
Transmission: 700-R4
Ok its been happening for a while now, its just gotton worse, and it usually goes away with a full tank of gas; however i have half a tank, and when i come to an abrupt stop, the car will studder, and about 35% of the time stall..
I know the problem is fuel, what could be the problem if it only happens after a stop?
And all you guy's funny post better not be posted, i ask the mods to delete those posts wrather then lock this thread.I need your guys' help, so please....
shane
Old Dec 2, 2004 | 10:47 AM
Morley's Avatar
Could be a ruptured pulsator in the tank, allowing air in with the fuel upstream of the pump, or more likely just bleeding off pressure to where the engine can't idle.
Old Dec 2, 2004 | 12:16 PM
ljnowell's Avatar
No funny posts here, its all sad actually.
perhaps fuel pressure? Or wait, its easier just to come on here and expect people to fix it for you.
Have you checked your Knueter valve?
Old Dec 2, 2004 | 12:18 PM
THEGENERAL's Avatar
Car: 1966 impala , 1998 sebring vert,1978 buick regal turbo, 1991 chevy silverado 3/4ton 4x4 lifted
Engine: 283, 2.5,3.8 turbo 350
Transmission: powerglide,auto overdrive, th350,4L80
possibly the fuel pump is going out d00d...
oh yeah i almost forgot about the Knueter valve it could be plugged....
Old Dec 2, 2004 | 12:30 PM
vernw's Avatar
Car: 91 Formula WS6 (Black, T-Tops)
Engine: 383 MiniRam (529 HP, 519 TQ - DD2K)
Transmission: Built '97 T56, Pro 5.0, CF-DF
Axle/Gears: 4.11 posi Ford 9"
You guys are really bad.......
Definitely check the fuel pressure and filter, and see if it does the same thing at an idle if you rev it up and abruptly let off the gas.
Old Dec 2, 2004 | 12:35 PM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
UH........ Don't stop sorry, couldn't help it
Old Dec 2, 2004 | 01:09 PM
PhAnToMs's Avatar
Car: 1984 Z28
Engine: 5.7
Transmission: Auto w/ shift kit
abrupt stop
if you let off the gas earlier and hit the break earlier you wont come to such a hard stop and should not have a problem
Old Dec 2, 2004 | 01:19 PM
z28monster's Avatar
Car: 86 IROC-Z
Axle/Gears: 3.42s/posi/disc
on the older camaros and TAs they had non baffled gas tanks in them... and i know from experience of owning 3 like this that anything 1/4 tank of gas or under if you turn to sharp the engine will stumble for a sec or two because the gas is sloshing around int he tank due to not haveing baffles to stop this....
maybe you are haveing the same problem... because you say it doesnt do it when you have a full tank of gas...
have you ever tried to blow a donut with 1/4 tank of gas.... atleast in my car you cant do it unless you have atleast half a tank of gas again due to the older style gas tank....
i think this is your problem man..... to fix this about the only thing you can do is buy a newer gas tank for your car out of a newer model 3rd gen... im not sure what years got the baffled tank.... but this is def a big flaw that gm had in the older 3rd gens.... because it annoys the crap out of me when i want to take a corner real fast and the engine dies out for a sec because i have under a 1/4 tank of gas in it......
id be willing to say this is your problem.....
:lala: lol and you other guys are mean lol just help the kid out.... you guys dont have to rag on him all the time lol.....:lala:
Old Dec 2, 2004 | 01:21 PM
THEGENERAL's Avatar
i think the baffled tanks came in the 90-92 cars if i recall correctly ....
and this could be the problem but if i were to replace a tank in a thirdgen id go get a nice 4th gen tank and be done with it
Old Dec 2, 2004 | 03:24 PM
Streetiron85's Avatar
Car: '85 IROC
Engine: LB9
Transmission: 700 R4
It could also be that your fuel ga isn't as accurate as you give it credit for being, and your tank is actually down to 1/8 when it reads 1/2. Then when you stop or turn the fuel sloshes, and the pump picks up air dropping the fuel press to 0 instantly.
I had a car that did that any time the ga read below 1/2 tank, it was actually nearly empty.
Your splling is improving. Keep ip the good work and pretty soon you'll be ready to work on your car without putting your fingers in the alt fan.
Old Dec 2, 2004 | 07:28 PM
Scottlb9's Avatar
Car: 1991 Formula
Engine: 5.0 TPI
I think those only came with the 1LE option but I'm not 100% sure.
Shane,
Is your car running rich? Better yet, if you rev the motor to about 3 grand for a few seconds and let you foot off the gas completely, do the rpm’s drop real low, like in the 350-400 rpm range, maybe even stall? If so, check your EGR connections and maybe the ERG itself.
Old Dec 2, 2004 | 07:46 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
Shane, when you say "abrupt stop", what do you mean? If you coast to a stop, it doesn't do this, yet if you go happy on the brakes, it wants to stall?
Old Dec 2, 2004 | 10:00 PM
therckid's Avatar
Car: 1986 Trans Am
Engine: 305 LB9 TPI
lol,i'm soo stupid, my maf sensor, the connection on the throttle body side became loose, and when i stopped it opened even wider.... that was my problem
Old Dec 2, 2004 | 10:25 PM
TTOP350's Avatar
My car has the baffeled tank and its a 89,I think anything that had the performance package got the tank .. it finally became standard around 90-91 on all models ................... I think
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
Thatll definatly do it. Bottoms out the MAF reading and the fuel when no signal is present.
Infested
May 22, 2018 11:56 PM
Wade787b
Sep 29, 2015 01:15 PM
Bryan F
Aug 18, 2015 02:28 PM
Jake_92RS
Aug 17, 2015 09:42 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
