setting rocker arms
Old Jun 6, 2001 | 09:52 PM
fast iroc's Avatar
setting rocker arms
when setting them while the car is running.You tighten them right to the point they stop tapping.Then how much more do you tighten them i heard 1/4 turn and a whole turn which is it?
85 iroc with 305 weind single plane intake, 650 double pumper, msd crap,holley mechanical fuel pump,cam is 230 duration 453 lift, 350 turbo tranny, 2400 stall soon to be 3000, 125 horse shot of nos, 4.10 gears, lower end is built and i shift the 305 at 6500, just for you 305 doubters pull up next to this 305 and get a little
Old Jun 6, 2001 | 10:12 PM
Engineboy's Avatar
Car: yep
Engine: uhuh
Transmission: sure does
I personally like to set them while not running, but to each his own
You can set them to anywhere between 1/4 and 1 1/2 turns...everybody that replies to this will most likely have a different spec that they like.
I set mine at 1/2 to 3/4.
ASE Mechanic/Machinist/Smog Tech
1999 NBM Trans Am
1986 Chevy 3/4 ton pick up
1981 corvette
1995 Kawi ZX6R
and 2 POS commuters...
R.I.P. #3
"He can see air"
Old Jun 6, 2001 | 10:17 PM
fast iroc's Avatar
Yeah i was thinking 1/2 t 3/4's turn thanks.
Old Jun 6, 2001 | 10:23 PM
firbird's Avatar
what? you do it with the car running i did not know you could do this doesnt oil go every where?
Old Jun 6, 2001 | 10:41 PM
fast iroc's Avatar
Your new to cars are'nt you.You can do it with the car running or not running.Anybody that does'nt know that must be new to engine work.You learn something new eveyday.
Old Jun 6, 2001 | 11:51 PM
firbird's Avatar
yep
SLNTSCPE
Aug 22, 2015 09:15 PM
Zeek1041
Theoretical and Street Racing
Aug 21, 2015 08:45 PM
Dialed_In
Aug 20, 2015 01:45 PM
Cameeeero
Aug 20, 2015 03:06 AM
