which engine is..
Old Dec 4, 2004 | 10:39 PM
Phoenix8936's Avatar
which engine is..
ok i have read someplace that one engine that was put in 3rd gens had a fule boiling problem..im pretty sure that it was the LB9 engine...but i heard someone say that it was the L89 engine...which for that engine being so popular i doubt it was that one.and im thinking that it was the LB9..am i correct?
Old Dec 4, 2004 | 10:41 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
You mean vapor lock? If so, the LG4 (carb cars) were good at that. So good in fact, GM decided to put in an in-tank "helper" pump to assist the block-mounted one.
Old Dec 4, 2004 | 10:44 PM
ok that coulda been it but i thought it was an actual fuel boiling issue..and i thought it was in an injected engine...and if i remember right i think it was only a late 80's engine and i read it in the firebird redbook...if i remember right to my early days of driving ....
Old Dec 4, 2004 | 10:52 PM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
LG4 & L69's without intank pumps were known to have vapor lock issues. Having an in tank pump fixes that problem since the fuel is under pressure all the way up to the carb or injection unit.
Old Dec 4, 2004 | 10:53 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Well, when vapor lock occurs, the fuel inside the fuel lines more or less boils, prematurely evaporating before it's technically supposed to.
Old Dec 4, 2004 | 10:57 PM
it was a L69 with the problem..i see..well thanks guys that took that off the table..with an in tank pump all problems were solved..altho that does make sense..
well ill just ignore that car..didnt matter much anyways cause id prolly yank that engine this winter..
Old Dec 4, 2004 | 11:05 PM
kretos's Avatar
Car: 89 Iroc
Engine: lb9
Transmission: wc t-5
Axle/Gears: 10 bolt 3.08 posi
another reason why the l69 sucked so bad
Old Dec 4, 2004 | 11:09 PM
and all of these wonderful L69's were "g" engine codes right?....man this owner isnt goin to like hearing what his car is worth to a true follower of f-bodies...lol
Old Dec 5, 2004 | 12:11 AM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
It was the early carb'd engines w/o in tank pumps that had that problem.
My 350 (swapped) also had that problem occasionally, since it used the L69 fuel lines on it and doesn't have an in-tank pump. As soon as I rerouted the fuel line from the block-mounted pump to the carb, I never had the problem again.
Kretos - Why bash the L69? It was one of the best 3rdgen engines GM had. IMO, it was 2nd only to the L98, because the 305 TPI (this is just my opinion here) was a truck motor. Sure, it made alot of torque, and decent hp, but it was a low rpm engine. The L69 was designed to make its power at higher revs than the TPI 305s were, and that made it much more fun to play with than TPI. I had an L69 in the Z28 I have now, and it was much more fun that the stump-puller TPI engines were, and I've driven a few.
84z96L31vortec
Aug 20, 2017 12:16 AM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
Reddeath210
Oct 6, 2015 08:20 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
