How much HP does a 305 have?
Old Jun 6, 2001 | 07:21 AM
Irish_boy_305's Avatar
I've heard various rumors. I'm wondering I have a 87 305 carb'd. It has a Hypertech stage 2 chip on it and a k&N filter on it so far. how much HP do you guys think I have so far?
87Camaro RS
305 carb.
Just got it so working on mods
Old Jun 6, 2001 | 08:11 AM
irocbsa's Avatar
If your engine is the 305 H.O. then it has 190 horse stock. I'd say with your mods now you probably have around 200.
bsa
"If they do not run, Then they will die." - Stonewall Jackson
'87 IROC, 355 TPI, Converted to SD, 700R4, B&M Megashifter, 3.42, Trick Flow Twisted Wedge Heads, Edelbrock Intake, Accel Runners, Comp Cam, Crane Gold rockers, Lucas 24# injectors, Edelbrock headers, Flowmaster 3'' exhaust, Mallory Ignition, Transgo Performance Shift Kit, Corvette Servo, 2,000 Stall Torque Converter
Old Jun 6, 2001 | 08:16 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
Check out https://www.thirdgen.org/newdesign/tech/techdb.shtml , the tech database on this board.
Looks like you started out with 165 HP. You've probably added about 5 more, minus losses from wear. It does not look like the L69 190 HP was available that year.
82 Berlinetta, orig V-6 car, now w/86 LG4/TH700R4. 2.93 limited slip. Cat-back from '91 GTA, Accel HEI SuperCoil. AMSOIL syn lubes bumper-to-bumper. Daily driver, work-in-progress (LG4 w/'87 LB9 block, ZZ3 cam and intake, World 305 heads, Hooker headers & y-pipe, 3" Catco cat & 3" cat-back).
57 Bel Air, my 1st car. 0.030 over 396, 9.7 CR forged TRWs, Weiand Action+, Edelbrock 1901 Q-Jet, GK 270 cam, Magnum rockers, Jacobs Omnipack, 1-3/4" Hedders & 3" Warlock header mufflers, TH400 w/TCI Sat Night Special conv & Trans-Scat shift kit, LT MegaShifter, 3.08 8.2" 10-bolt w/Powertrax, AMSOIL syn lubes bumper-to-bumper. Best 15.1/95.5 @ 5800' Bandimere.
[This message has been edited by five7kid (edited June 06, 2001).]
Old Jun 6, 2001 | 08:28 AM
Wow, only 5 hp from both those mods so far? Damn. Well im about to mod the carb a little and put on a new flowmaster 40 series exhaust system. Hopefully with all this i can bring it up a little more than 170hp.
87Camaro RS
305 carb.
Old Jun 6, 2001 | 08:38 AM
Drekken's Avatar
Check out the engine section of this webpage it tells you all the stock information of the motors on all the third gen camaros
http://www.angelfire.com/biz/chevroletcamaro/
Old Jun 6, 2001 | 08:40 AM
bbtaz97's Avatar
Car: 91 RS
Engine: 350tpi comming soon!
Transmission: fixed the 700r4 again!
with some mods, ther more you add the more you get out of the mod. example: if you added headers the hp gain will be greater for the muffler. kinda like that.
91 camaro RS
- 305 TBI
Mods: Performer TBI intake, 1" TBI spacer, K+N, jet fan switch ,160 thermo,Accel control module, Jet Stage 2 chip, edelbrock TES headers, Compleate 3" Flowmaster exhaust, Edelbrock springs, KYB struts and shocks, 700R4 built by TSI, SLP tq converter, b+m trans cooler, white guage faces, megashifter..
next month: spohn LCA's and panhard rod, BMR relocation brackets, 323 gear
Old Jun 7, 2001 | 08:16 AM
irocbsa's Avatar
I thought 87 was the last year for the H.O. motor. Might be wrong....gonna go check.
bsa
Old Jun 7, 2001 | 08:27 AM
82camaro's Avatar
Car: 82 camaro SC
If you want big HP increases you need a whole combination of parts. Example: Mod the carb, aluminum intake, better cam, headers and/or exhaust improvements.
82 camaro--original steering wheel, brake/gas pedals, seats--everything else modified
82camaro
Old Jun 7, 2001 | 05:10 PM
One Eyed Jack's Avatar
No single mod can give major HP
besides nitrous but thats temporary
1992 Pontiac Firebird (stock)
- 5.0L V8 TBI / Automatic Trans / Every option, excluding leather
- Killer car audio system:
  • Aiwa CDC-MP3 head unit
  • Rockford Fosgate 360a2 amp
  • pair of 12" MTX Thunder 5000s in a custom box
  • Pioneer 3-way 6x9s, soon to add more more more!
pjsparts
Oct 29, 2025 06:39 PM
Ranbo108
Sep 9, 2015 12:20 PM
383cam
Sep 9, 2015 06:01 AM
rsrookie
Sep 5, 2015 07:08 PM
Formula_88AE
Sep 3, 2015 01:47 PM
