Wont turn over. Just drains battery
Old Dec 6, 2004 | 07:41 AM
olong_us's Avatar
Car: 1986 IROC Weekend, Jetta VR6 Daily
Engine: 350 .030 over 5.7 TPI
Transmission: 700-R4 Rebuilt
I dont get it. When i go to try to start my 86 Iroc (305 TPI) it makes no noise but the fule pump pumping. I trun it to start and they lights dim and nothing happens, not even a click sound. Did i burn the stater up? the solinoid? any ideas before i spend a bunch. I checked the fuse block and everthing is ok.
Old Dec 6, 2004 | 08:50 AM
CraZ-28's Avatar
Car: 1991 Z-28
Engine: Can you say stroke?!?!
Transmission: 700-r4
It's hard to say. Your best bet is to take both the battery and starter down and have them both tested. Once they are tested then go from there.
Hope that helps.
Old Dec 6, 2004 | 12:13 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
If everything works except the starter, I would suspect a faulty solenoid.
Old Dec 6, 2004 | 12:53 PM
ME Leigh's Avatar
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
Hope that helps.
Best advice ever, get everything tested.
I'm going to bet its the battery or a bad connection/ground. But as Mike said it could be the solenoid. But since its getting colder out the battery has much less power.
Old Dec 6, 2004 | 05:41 PM
incus86's Avatar
Car: 1992 trans am ws6
Engine: l98
Transmission: t-56
same thing happened to me...definately check your starter wires to see if they are loose.
Frozer!!!
Jan 19, 2024 04:55 PM
Street Lethal
Apr 30, 2019 12:14 PM
Derick15
Sep 17, 2016 05:28 PM
djmarch
Aug 9, 2015 05:27 PM
