blower motor doesn't work sometimes
Old Jun 7, 2001 | 02:12 PM
Greg's Avatar
Car: 89 Formula T-Top
Engine: 388 MiniramII
My blower motor has not been working correctly for awhile now. I replaced the switch and the resister. I also fixed the plug that connects the two red wires together since that burned up. When the blower motor is working it works correctly at all speeds but sometimes it won't work at all. What could the problem be??? Could it be the motor or is it in the wiring somewhere. Thanks in advance...this board is the best!!
'89 Formula 383 TPI
Old Jun 7, 2001 | 03:24 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Could be the motor. It could also be the connector that feeds battery (ignition actually) to the control head. It is the same style of connector as the one with the green and black wires in it, which can also cause the motor to quit working.
ICON Motorsports
Old Jun 7, 2001 | 03:50 PM
Greg's Avatar
I followed your advice by doing a search and I checked the brown wire and the connector that is behind the HVAC controls. The connector is great. Now I'm stumped.
'89 Formula 383 TPI
Old Jun 7, 2001 | 04:05 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Check the one under the hood, probably not far from the one you looked at in the big red wire, that has the black and green wires in it. If that's OK, all that's left is the relay and the motor itself.
I've seen intermittnet motors before.
ICON Motorsports
Old Jun 7, 2001 | 09:03 PM
Rob P's Avatar
Car: 89RSconvtZZ4TPI
Engine: ZZ4TPI
Transmission: 700R4 TRIPP TRANNY
My 89RS with 193K on the stock blower motor is starting to do the same thing. Turn the switch and nothing, let it set or play a little bit and it starts working. It's probably the motor dying.
Rob P
89RSconvtZZ4TPI
Edelbrock Hi-Flow Intake
SLP Dual Cold Air Intake
1 5/8" Headers
Semi-Siamesed Runners
MSD6AL/AdjFPR/IROC frnt@rear swaybar/wonderbar/steeringbox/alum drvshaft/ Alston SFC/3:23posi disc rear/MAC LCA/H.Adams Panhard Rod/KYB struts/ shocks/
92Z28convt5spd
71Impala convt 402BB
BETTER DRIVING THRU SUPERIOR HORSEPOWER!
1992rs/ss
Jan 31, 2025 05:10 PM
Frozer!!!
Jan 19, 2024 04:55 PM
jhawkeye
May 25, 2022 06:33 PM
Wade787b
Sep 29, 2015 01:15 PM
TheExaminer
Aug 26, 2015 04:59 PM
