Time for an Oil Change, but what type of Oil?
Old Jun 7, 2001 | 01:24 AM
rpettway's Avatar
Well it is time for an Oil change for 305 TPI 1987 Trans Am, but I do not know what type of oil to go with this time(summer). I have tried MaxLife 10W40, but I want to try something like Mobile 1 synthec oil. I did a search and some say 15w50 or 10w30 What type of oil (brands and weights) do you prefer I sould use in my car?
Thanks,
RPettway
305 TPI Engine
Bosch Platnium Sparkplugs
8.5mm CraneCams FireWire
MSD Cap and Rotor
Purelator Air Filter
Purelator Oil Filter
Flowmaster 80 Muffler
HI-Flow Cat
And More to Come....
Old Jun 7, 2001 | 03:02 AM
83_TA's Avatar
I only use ROYAL PURPLE "41" RACING OIL in my 83 TA.. They also have the regular SAE synthetic oils as well.. This is a full synthetic & a bit on the pricy side, but can actually increase your horsepower..
This was recommended to be by the guy that did my motor rebuild..
Here is a link to Royal Purple if you want to check it out..
http://www.synerlec.com/
Old Jun 7, 2001 | 09:24 AM
Ken88GTA's Avatar
Definitely Mobil 1! 10W30 should work just fine in your part of the country.
Ken
[This message has been edited by Ken88GTA (edited June 07, 2001).]
Old Jun 7, 2001 | 09:45 AM
88firebirdTBI's Avatar
Is it true that using synthetic oil will increase horsepower? Just wondering
Steve
88 Firebird TBI(WS6),TH700R4 - Open Element, Cat Delete, K&N filter 14*4 element, American Thunder Flowmaster Catback Exhaust, 180 Stant thermostat, Accel cap and rotor
Old Jun 7, 2001 | 10:18 AM
Xenodrgn's Avatar
<font face="Verdana, Arial" size="2">Originally posted by 88firebirdTBI:
</font>
Yep.
synthetic oil = less friction = less engine load = more HP
I just use regular oil, 10W30 year 'round. I want to switch to synthetic, but with the 143K I have on my engine, it would probably find it's way through every little leak, therefore, regular oil works fine with me. I just bought a case of Havoline just because it was the cheapest name brand stuff at the time.
If your engine is relativly fresh, synthetic should be fine.
1985 Camaro SC - 2.8L, auto.
Mods:
Removed air baffles, mandrel bent cat-back pipes (but stock replacment muffler, Dynomax Turbo and Catco converter are on thier way)
Old Jun 7, 2001 | 10:19 AM
Steves ZZ5's Avatar
</font>
It may "free up" 1%-2% more horsepower, but you will never notice it. That shouldn't be the reason to use synthetics though. the improved lubrication, corrosion resistance, and extended life should be the main reasons.
RPettway, If you switch to synthetics, feel free to use a 5w30 or 10w30 year round.
Old Jun 7, 2001 | 01:41 PM
86SCBNJ's Avatar
I use mobil 1 in all my cars. 10w/30 is all you need. You can use a longer filter, which holds more oil, if you want a little extra insuarance.
Old Jun 8, 2001 | 01:18 AM
IROCZTWENTYGR8's Avatar
Administrator
Car: Red 87 IROC-Z28 T-Top
Engine: 5.7 Tuned Port Injection
Transmission: 700R4 Auto
Axle/Gears: BW 9-Bolt 3.27
Yeah.
89 RS
Looking For:
87 IROC-Z28 350 TPI
[This message has been edited by IROCZTWENTYGR8 (edited June 07, 2001).]
eightsixseven
Dec 16, 2024 01:50 PM
maroe624
Apr 16, 2017 08:29 AM
Navy8125
Aug 21, 2015 09:32 AM
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
