Engine Building for Turbo's & S/Cs
Old Jun 8, 2001 | 03:26 AM
auxout's Avatar
Car: 92 RS
Engine: VSux
Transmission: Flux Capacitor
I couldn't decide whether to post this in power adder forum or here so if you mods want to move it be my guest. Now what I was wondering was what considerations do you have to take when you are building an engine to take a turbo or supercharger? Is it just about the same for both or different things for both? I don't expect you to tell me how to build an engine or anything in this post, but any website/book recommendations are welcome.
1992 RS 3.1
1985 POS (SC 2.8 CFI)
Old Jun 8, 2001 | 07:43 AM
JoelOl75's Avatar
Car: 88 Firebird WS6
A well built motor specifically set up for forced induction has the turbos/sc scale matched to the motors cubes,demand,rpm... I can't egt into detail here because I'm not fully sure on how they figure the efficiency or the 'curve' of the PSI's..
I do know low ratio pistons (forged) with a wider ring gap are req'd for serious boost. Also there's a trick of drilling two counter-secting holes into a main to rod oil passage and directing it toward the bottoms of the pistons and putting a sized orfice there to spray oil on the bottoms for cooling. Also for more serious street strip blown apps I hear of "multi-stage" EFI where you run cheap pump gas in normal driving conditions, but at WOT, a secondary system kicks in to supply either methanol, race gas, or water (to reduce/eleminate detonation).
Forged cranks, pistons, and the best of the bottom end is a good direction, as is aluminum heads and the proper cam.
Just staying out of detonation is the important part.
Terrell351
Jun 13, 2021 01:13 PM
italiano67
Dec 11, 2016 09:21 AM
sreZ28
Aug 14, 2015 07:48 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
Jake_92RS
Aug 11, 2015 10:39 AM
