EGR Removal?
Old Jun 10, 2001 | 12:29 AM
RadarRunner's Avatar
Car: 1987 Z28
Engine: LG-4 305
Transmission: 5-speed
EGR Removal?
Would it cause problems if I removed the egr from my 1987 lg4 4bbl?
1987 Z28 Black & Silver 305 LG4/5-Speed . . .
NRA/AMA/FOP/IUPA/Blue Knights
Old Jun 10, 2001 | 06:13 AM
ede's Avatar
ede
well if you have e check it will, or might. it was put there for a reason, preformance wasn't it. lot of people do block it off with no problems. you could do it and it you have problems remove the block off plate.
ICON Motorsports
1st & 3rd
MM Black Diamond 538 F&AM
Old Jun 10, 2001 | 10:49 AM
Vader's Avatar
RR,
Unless you have a problem with the EGR or the space it occupies, there is really no reason to remove it. It doesn't cost you any performance if it is working correctly. Before you decide, you should probably read the Tech Article on EGR function. GM Tech wrote the article, and was pretty thorough in describing its benefits for performance.
Later,
Vader
"Let the bodies hit the floor!"
Adobe Acrobat Reader
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
MY87LT
Aftermarket Product Review
Jun 7, 2016 09:47 PM
Fronzizzle
Sep 8, 2015 12:10 PM
Stryker412
Sep 7, 2015 09:11 AM
rjcme
Sep 5, 2015 01:23 PM
