car stays running with key off
Old Dec 18, 2004 | 05:14 AM
nathan2003's Avatar
Car: Camaro
hey, quick question, whenever i go to turn off my car i turn the key off and pull it out and the motor continues to run for like 10 - 15 seconds after the cars been turned off... what may be the cause of this?? thx.
Old Dec 18, 2004 | 06:34 AM
ede's Avatar
ede
change the timing ought to help and make sure the tune up is good
Old Dec 18, 2004 | 08:14 AM
White91GTA's Avatar
Car: 1991 Trans AM GTA
Engine: 5.7L TPI
That is called dieseling...I agree with what Ede said about the tune-up and timing adjustment. When was the last time you did a tune-up on the car?
Old Dec 18, 2004 | 12:05 PM
DENN_SHAH's Avatar
Car: 83 POS monte carlo 2015 chevy P/U
Engine: 92 5.7 tpi 5.3
Transmission: 700r4 6L60E
Axle/Gears: 2.42 too high
a 91 dieseling? i would think that if its carbed, if its TBI or TPI & dieseling you have a fuel leak into the engine. if its not dieseling but runs normally for those 10 - 15 seconds after you turn the key off, unhook the cooling fans & see if that stops it.
if you are carbed & are dieseling, then what ede & 91GTA said applies & also check your base idle speed.
Old Dec 18, 2004 | 06:57 PM
88IROC350TPI's Avatar
Car: '89 IROC-Z
Engine: Canfield 195 headed 358ci
Transmission: TH350, Art Carr 9.5"
Axle/Gears: 3.92 Dana 44
Yeah I'd say 10-15 seconds is a lot for it to be "dieseling"
Like mentioned above, unplug the cooling fans and see if it still does it.
midge54
Dec 27, 2019 04:14 PM
Kaweh
Aug 9, 2015 02:54 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
Sherpajames
Aug 7, 2015 06:56 PM
