TACH Reading Off
Car: 84 Z28 Convertible 2 Seater
Engine: Dart Little-M SBC 400
Transmission: Pro-built Automatics 700R4
Axle/Gears: Strange Engineering 3:73
TACH Reading Off
I Change over to a 145mph Speedo now my guages or screwed up.The TACH is reading about 1500 more rpms than the actual engine speed. It usually ides at 900-1000, now she is close to 2500 rpm. What could have caused this mishap?
Car: 85 SC, 86 Berlinetta
Engine: V6, V8
Transmission: 700r4, 700r4
Great, I just bought a cluster so I would have a tach to protect my engine.
That's why you see those pictures of the extra tach hooked up to the side.
Can you adjust the stock tach?
Are the gauges off as well?
That's why you see those pictures of the extra tach hooked up to the side.Can you adjust the stock tach?
Originally posted by Saigon_Bob
tachs dont protect you engine.. a rev limiter will. no you cant adjust it
Engine: V6, V8
Actually, I didn't mean that the tach itself would protect the engine (bad wording on my part) but that I would know when it's reaching it's upper limit.
If it's off by 400-500 RPM then I would be overreving it in on a regular basis.
By the way, does anyone have any experience with the shift lights? Would that be a way to know when to shift? I have an auto anyways but I sometimes hold the shift back until it's up there. I have a newly rebuilt engine and tranny and want to keep an eye on it.
Could it be possible that I might have a V6 tach hooked up to a V8 and those 2 extra cylinders is causing the rpm to read higher than they are. If the tach dosent know the difference and registers the two extra cylinders as a faster rpm since its going by the spark of the ign system.
Just a thought:
Just a thought:
Car: 1991 Camaro RS
Engine: 357cid
Transmission: T5 Swap
Axle/Gears: 10bolt 7.5" 3.23 soon to be 3.73
Just a thought:
Just a thought:
Engine: V6, V8
Isn't it necassary to shift an auto "manually " to get the most out of it? Why do they make ratchet shifters and slap sticks?
I thought autos shifted too early when you wanted the most out of it.
:shrug:
:shrug:
:shrug:
:shrug:
Car: '89 Formula 350 & '86 Z28
Engine: L98 & 355ci
Transmission: 700r4 in both
My car is slower shifting it manually, it doesnt shift when I actually shift it.
How many RPM are you wanting to shift at?
Car: 1991 Camaro RS
Engine: 357cid
:shrug:
:shrug:
Engine: L98 & 355ci
Automatic shift points can be adjusted to wherever you like them, regaurdless of shifter.
In non-electronic transmissions its all about govenor pressure overcoming throttle pressure to get an up shift. This is what changing the weights on your govenor does.
Engine: V6, V8
Originally posted by Morley
Recalibrate the trans to shift when you want it to under WOT. Now-a-days people want the manual auto shifters for the "cool factor" they think it gives or for special purpose. For a street driven vehicle those shifters are pretty much useless.
You make it sound easy to recalibrate the shift points. How easy is it?
Are these shifters useful on an off road situation? Where and why?
What shifter would you recommend if you did use one?
The reviews I've seen make them sound like a waste. Just one more thing to tinker with or go wrong.
I liked the one on my Goat, it was simple and foolproof.
Actually I don't even have all the stats on my new engine yet.
But I've almost always had to hold back the shift to reach the recommended shift RPM.
Doing this manually does open up opportunity to damage the engine on a mis-shift.
So with the set up I have where the engine and tranny were built together- I shouldn't ever have to shift it manually? -Ever?
[QUOTE]Originally posted by Saigon_Bob
ratchet shifters allow you to shift when you want easier than the stock one, but if you put it in drive it still works like normal....... i know that if i was to control the shift which i have a few times..... i shift b4 the trans does..... [/QUOTE
O.k. what would be the purpose of controlling the shift if you shifted before the tranny normally would? Are you trying to keep it in a certain power band and why?
Thanks for your comments but I'm becoming more confused on this subject.
What really is the purpose of the ratchet shifter?
Car: 1991 Camaro RS
Engine: 357cid
ratchet shifters are useful for racing but are mearly for a cool factor on teh street
Hotrodboba400
Dec 10, 2019 07:07 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
