wierd noise
Old Dec 20, 2004 | 04:40 PM
thomas_iroc's Avatar
wierd noise
my crank pullie makes a loud squiling noise. is that bad? can it be fix with a little wd40?
Old Dec 20, 2004 | 04:54 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
You may stop the squeaking, but I'm not sure I'd call it fixed.
You might try some belt dressing after you've made sure you don't have any alignment problems with the pulleys, the belts are properly tensioned, and that the belt(s) is(are) in good condition. Otherwise, it's more of an annoyance than anything else.
Old Dec 20, 2004 | 05:46 PM
five7kid's Avatar
Okay, additional info via PM...
Does it with belts off, you've got a wiped out engine bearing, most likely.
mud runner
Nov 2, 2015 07:30 PM
sleprock
Interior Parts Wanted
Oct 3, 2015 11:01 PM
sjorgens
Oct 1, 2015 07:54 PM
lanceflame44
Sep 25, 2015 12:28 PM
andy74
Sep 3, 2015 08:41 AM
