ICM Questions
Car: 1986 Trans Am
Engine: 305 LB9 TPI
Transmission: 700-R4
ICM Questions
ok guys i have fuel and i have air....
SPark is the question my rents went out and bought the ICM for me, even though i had the darn car cranking for 3 seconds, and the one plug i had sparked once.... is that bad or good?
cranking for 3 seconds and sparking once.... is that bad?
Car: Tree Huggers
Engine: Do Not
Transmission: Appreciate Me.
BUY A ****ING BOOK ALREADY AND FOLLOW THE INSTRUCTIONS THEREIN!!!
And it could be bad, or it could be fine. Knowing you Mickey, I am suspect of your testing methods.
Car: 1986 Trans Am
Engine: 305 LB9 TPI
i ummmm pulled the boot, and since i know the boot likes to arc when it was disconnected when i instlaled my headers... half of the boot is gone somehow but it still works....
SO i sit it next to the headers, and it arced once....
Shane
Shane
Car: Tree Huggers
Engine: Do Not
Mickey, go buy a Chilton's and Haynes books and follow the instructions therein to troubleshoot stuff. You are as wrong as you were about the damn MAF.
Car: Tree Huggers
Engine: Do Not
Oh, and maybe look in the friggin' SEARCH for something like 'check AND spark'. Start trying to use the grey goop G0D stuck between your friggin' ears.
Car: Gutted 92' RS TRACK ONLY / '86 Mustang gt 'vert / 1982 Yamiaha xs400 Cafe Racer
Engine: L03; TBI is IT! / 5.0HO (306) SFI / 400cc air cooled twin
Transmission: 700-r4 / WCT5/ 6-speed close ratio
Homie you need to speak more clearly. It's hard to understand what you are saying. If people didn't have to decode what you are posting, I bet you might get more help.
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
Whats that 'search' thing that you speak of?
Holding the boot next to the header isnt the best way to check it. A spark tester, or just holding the plug up against the head would be better. And, from the sound of it you need to plug wires if theyre damaged like that.
Car: NCC-1701-D (docked in AZ)
Engine: impulse drive
Transmission: fusion reactors
Axle/Gears: Rescued from the Borg by my crew
Why does tgo allow him to start three or four threads on the same subject?????????????????????
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
Car: 83WS6TA
Engine: ZZ4
Transmission: TH350C
Axle/Gears: 3:23
Shane
Shane
