second cooling fan???
Old Nov 8, 2000 | 10:08 PM
MilehighBird's Avatar
Car: 1987 Firebird Formula
Engine: 305 LG4
I have an '87 formula with an lg4 engine.My hayes and gm helm manuals both refer to a secondary fan and secondary fan switch.Should i have a second cooling fan or is the secondary fan supposed to operate the cooling fan after the car is shut off.
There is only one fan in my engine compartment.Any info on this subject would be appreciated.
Old Nov 8, 2000 | 10:34 PM
rsilver's Avatar
Mile high, I have an LO3 and it only has one fan. I think only the HO engines had dual fans.
The is a good article in the archives on how to swap to dual fans if you want, but if you are not over heating, you probably don't need to be..bob
91 camaro RS convert
t-5
open element air cleaner
TBI spacer
Flowmaster muffler
3.42 Torsen posi
Old Nov 8, 2000 | 10:50 PM
Grim Reaper's Avatar
Car: Death Mobile
Engine: 666 c.i.
You have to have air conditioning to get the second fan.
Old Nov 8, 2000 | 11:02 PM
Engine: 305 LG4
Thanx rsilver,that's a good article.I know the 350's came with the dual fan set up on the radiator.I was wondering about two seperate fans though. I was told that certain carburated models were equiped with a small secondary fan further back in the engine compartment.Supposedly it was to lower engine bay temps and help make hot starts easier with the carb.Should i have this seperate fan?
Old Nov 8, 2000 | 11:03 PM
Engine: 305 LG4
I do have AC Glen,i am also the original owner and have never removed anything.
Old Nov 9, 2000 | 05:30 AM
John Millican's Avatar
Car: 1997 Jeep Wrangler
Engine: 4.0L
Transmission: 5 speed
Axle/Gears: 8.8 rear, 4.56 gears, 4:1 transfer
You have to have an IROC to get the second fan.
86 Camaro Sport
383 Speed-O-Motive Crate Engine, Trick Flow Heads, 58mm Accel TB, 3.73 Auburn Pro, SLP Cold Air Induction and Headers, Dynomax Cat-back, Serpentine belt setup.
http://64.176.105.239/octride.htm
Old Nov 9, 2000 | 08:52 AM
Car: Death Mobile
Engine: 666 c.i.
Then it is an engine & a/c combo that determines whether you get dual fans. I have the L98 with A/C and I have the dual fan setup. The second fan only comes on when you have the A/C on and your engine temperature hits 235*F IIRC.
I suspect it may be limited to only TPI engines with A/C. Whether you must also have an automatic or it is limited to specific years, I cannot answer that.
Maybe a few others will tell you their year/engine/tranny combo with a/c that have dual fans.
For the time being, L98s with a/c are confirmed.
Old Nov 9, 2000 | 09:24 PM
rsilver's Avatar
My LO3 has air and one fan. BUT, it does like to overheat in 90+temps with air on in traffic....bob
t-5
TBI spacer
Flowmaster muffler
3.42 Torsen posi
Old Jun 14, 2001 | 01:57 AM
jeff-78's Avatar
My 87 305 5 speed has dual fans
Old Jun 14, 2001 | 01:59 AM
jeff-78's Avatar
oh yeah and i have a/c
Old Jun 14, 2001 | 11:39 AM
MikeInAZ's Avatar
Car: 86 T/A
Engine: 5.0 TPI
If I'm not mistaken the LG4 is a belt driven fan and not the electric fans. Your Helms manual probably covers several different models including TPI and is probably referencing a car other than yours.
<FONT SIZE="2" COLOR="red">Red 86 T/A</FONT><FONT SIZE="2"> 5.0 TPI</FONT><FONT SIZE="1"> </FONT><FONT SIZE="2">(LB9/WS6)
~HyperTech Cap/Coil/Rotor/AFPR
~Derale Adjustable Fan Switch ~ 170° Stat
~Flow Matched Injectors ~ K & N Air Filter
~Ported Plenum ~ Pirelli 245/50/16
~SLP TB Airfoil
~All Else Stock</FONT>
<A HREF="http://www.gmtips.com/3rd-degree/"><FONT SIZE="1" FACE="MS Sans Serif"><IMG SRC="http://www.gmtips.com/3rd-degree/cg/3rd-logo.jpg" WIDTH="100" HEIGHT="80" ALIGN="BOTTOM" BORDER="0"></FONT></A>
Linson
Oct 24, 2025 02:00 PM
sheachopper
Jul 31, 2019 11:27 AM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
Fanatic1074
Oct 2, 2015 03:47 PM
timbuck
Convertibles
Sep 28, 2015 12:31 PM
