How in the world to I disconnect this??!!
Old Jun 13, 2001 | 08:04 PM
Paul Riccioli Jr's Avatar
Car: 89 IROC-Z
Engine: 383
How do I disconnect the wiring harness where it goes into the firewall on the driver side? It looks like it goes into the dash area. Also I think I see two small wires that go under the trans tunnel....do you know what these are? I've almost got my entire wiring harness out!!!! The motor and tranny comes out this saturday!!!
Riccioli Performance Motorworks
--RPM Racing--
-Currently building first ever engine. 383 with Super Ram plenum and runners, Edelbrock lower intake, Bosch 24# injectors, AFR 190 heads, MSD ignition.
-Will be installing Baer Brakes
-Will be installing full Spohn suspension in rear
-Art Carr 700R4 trans??
Old Jun 13, 2001 | 08:11 PM
ColinOpseth's Avatar
Car: 1987 Camaro IROC-Z
Engine: 305TPI
wiring harness has a screw that holds it to the firewall, look, you'll see what i'm talking about.. i think it's 5/16s
Old Jun 13, 2001 | 08:14 PM
Vader's Avatar
Paul,
If one of the wires going under the trans tunnel is purple, and one is tan/black, you've probably found the harness for the torque converter clutch connection at the trans.
The bulkhead connector at the firewall is a PITA to disconnect. It generally involves removing a screw or two that hold the connector in place, then fighting the clips and tabs that hold the connector in place.
Later,
Vader
"Let the bodies hit the floor!"
Adobe Acrobat Reader
Old Jun 13, 2001 | 09:44 PM
Car: 89 IROC-Z
Engine: 383
Ok well here's what happened tonight....I tried to pry the clips off, but when I started pulling the connectors back the wires weren't coming with them. There was some black stuff like silicone under there too. Is this bad, or do I just need to pull some more?
Old Jun 13, 2001 | 09:46 PM
Guest
Guest
Posts: n/a
Did you take the bolt out? Im not sure if theres just one, I think so... but it has to be out first.
Old Jun 14, 2001 | 06:45 AM
Rob P's Avatar
Car: 89RSconvtZZ4TPI
Engine: ZZ4TPI
Transmission: 700R4 TRIPP TRANNY
I believe buried under all that weather proofing crap on the plug is a bolt/screw hold it in.
Rob P
89RSconvtZZ4TPI
Edelbrock Hi-Flow Intake
SLP Dual Cold Air Intake
1 5/8" Headers
Semi-Siamesed Runners
MSD6AL/AdjFPR/IROC frnt@rear swaybar/wonderbar/steeringbox/alum drvshaft/ Alston SFC/3:23posi disc rear/MAC LCA/H.Adams Panhard Rod/KYB struts/ shocks/
92Z28convt5spd
71Impala convt 402BB
BETTER DRIVING THRU SUPERIOR HORSEPOWER!
Old Jun 14, 2001 | 12:32 PM
Engine: 305TPI
Paul, did you read my last post There's a small bolt in the middle that needs to be removed, hehe
gta892000
Aug 11, 2019 11:16 AM
gt4373
Oct 8, 2015 10:37 AM
mcfastestZ28
Oct 1, 2015 11:23 AM
Damon
Sep 26, 2015 04:29 PM
scottmoyer
Sep 7, 2015 07:06 PM
