best method to clean carbon off pistons???
Old Dec 31, 2004 | 10:07 AM
Zap Racing's Avatar
Car: 1989 IROC Z-28
Engine: L98 350--modified
Transmission: 700 R4--modified
Axle/Gears: 4:10 Posi
Just got my heads back from the machine shop. Was going to start in this weekend on reassembly. What is the best method these days of cleaning the carbon off the tops of the pistons?
wire wheel?
carb cleaner?
I do have a air compresser, so blowing the crap out of the cylinders shouldn't be a problem, except I'm wondering how to make sure I don't get any small particles on top of the top ring area?
THANKS,
Craig
Old Dec 31, 2004 | 11:17 AM
blacksheep-1's Avatar
Car: 83 Z28
Engine: vortec 305 for now
Transmission: 5 speed
IMO, tape off the ring lands and LIGHTLY file down any edges (except the sides/of the top) and bead blast the pistons. This has a side benefit besides cleaning the piston, it will help in the spark knock dept.
...let the flaming begin
Old Dec 31, 2004 | 11:28 AM
ede's Avatar
ede
i use a wire brush on a bench grinder
Old Dec 31, 2004 | 11:31 AM
StealthElephant's Avatar
Car: 87' Iroc
Laquer thinner or acetone with wire brush.
Old Dec 31, 2004 | 11:32 AM
Car: 83 Z28
My error, I thought the engine was apart and you were using the old pistons with new rings. In your case, where the bottom end is still together, I would NOT bead blast them, you would never get the medium out of the cylinders.
Old Dec 31, 2004 | 12:08 PM
wesilva's Avatar
Car: 1966 El Camino Custom
Transmission: 200R4
Axle/Gears: 3:73 12 bolt with Brute Strength
This suggestion won't help you now but in the future when you get ready to tear a motor down, run about a quart of water slowly through the carb while the engine is still running. Then drain the oil and proceed with your engine pull and tear down. Your combustion chambers and piston tops will be clean...steam clean.
Old Dec 31, 2004 | 12:32 PM
DENN_SHAH's Avatar
Car: 83 POS monte carlo 2015 chevy P/U
Engine: 92 5.7 tpi 5.3
Transmission: 700r4 6L60E
Axle/Gears: 2.42 too high
spray some brake cleaner on the tops of the pistons & let it sit for a few minutes & blow it out, then spray them again & let it sit over night & blowing it off works good for me.
Old Dec 31, 2004 | 12:56 PM
Floor guy's Avatar
Car: 89 Firebird
Engine: 406 CI
Transmission: Pete K 700R4
Axle/Gears: 3:55
I have had good luck with wd-40. Spray them down well and let em soak for 12 hrs or more. The carbon wipes right off.
Old Dec 31, 2004 | 02:24 PM
THEGENERAL's Avatar
Car: 1966 impala , 1998 sebring vert,1978 buick regal turbo, 1991 chevy silverado 3/4ton 4x4 lifted
Engine: 283, 2.5,3.8 turbo 350
Transmission: powerglide,auto overdrive, th350,4L80
brake parts cleaner and a green scratch pad do the trick every time
Old Dec 31, 2004 | 04:21 PM
Zap Racing's Avatar
Car: 1989 IROC Z-28
Thanks for all the answers everybody!
I'm sure that between all the suggestions, I'll "GIT-R-DONE"
Just sprayed them with wd-40, gonna go out in a couple hours and spray them. My wife is going to the grocery store in a while so we'll get some scratchies--already got some brake cleaner.
EVERYBODY HAVE A GOOD SAFE NEW YEAR--AND THANKS AGAIN!!!
Craig
Old Dec 31, 2004 | 04:25 PM
TPI's Avatar
Car: '89 Trans AM/'88 GTA
Engine: (2) Tuned Port L98's
Put em in a parts cleaner with diesel, scrub em a bit.
then run on the wire wheel of a bench grinder..
youll be done in 20 minutes.
Old Dec 31, 2004 | 05:27 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Diesel fuel and a pressure washer (ie. a visit to the car wash)
Old Dec 31, 2004 | 06:11 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
I'm assuming if the pistons are still in the block, and the block is still in the car? Run each piston to TDC, get after it with a brass wire cup brush...do it dry...no solvents, this way you can shop vac anything out easily, or blow it out with your compressor. If you use solvents as described above, then the wettish deposits will stick in places you're trying to avoid.
Old Dec 31, 2004 | 06:35 PM
Zap Racing's Avatar
Car: 1989 IROC Z-28
Got it!
GIT-R'DONE!
THANKS AGAIN!
manualbrakes.com
Brakes
63
Apr 9, 2024 11:55 AM
gta892000
Aug 11, 2019 11:16 AM
350 IROC-Z
Camaros Wanted
Dec 18, 2015 03:58 PM
64Chief
Sep 12, 2015 08:05 AM
dimented24x7
Sep 6, 2015 03:51 PM
