Gas Fumes
Old Jun 15, 2001 | 11:08 AM
MINN IROC-Z's Avatar
Car: 1988 IROC Z
Gas Fumes
HI guys,
I have a 88 IROC-Z with a 350 TPI in it. I have noticed ever since I have owned it that I get a fuel oder in it when driving in town with the windows down at very slow speeds or idling at a stop light. I have changed the cap and can find no leaks in any of the fuel lines. The car runs great but this is starting to become anoying. I really notice it when after the car is hot and I am getting out of it after parking it. It will have a strong gas oder until it cools down. Could there be a problem with the purge solenoid on it to cause this not to vent the tank? There never seems to be any pressure on the tank cap when I remove it. How do these tanks get air vented into them anyway? Am I just not understanding it or is that a vent underneath down by the rearend? If you guys can help me it would be greatly appreciated because my girlfriend really doesn't like that oder if ya know what I mean. Thanks Dennis
Old Jun 15, 2001 | 11:36 AM
ede's Avatar
ede
check the charcol canister to see if it's saturated with fuel, good chance it is if you're smelling gas and have no leaks.
ICON Motorsports
1st & 3rd
MM Black Diamond 538 F&AM
Old Jun 15, 2001 | 02:00 PM
Ken88GTA's Avatar
Hey Minn,
If you walk around the car, can you tell where the odor is strongest? I've been dealing with the same problem, tried a new charcoal canister, helped a little but I think it may be my filler neck. That seems to be a common problem for our cars. I notice more after going around a turn. If you never have pressure behind the cap, maybe it is constantly venting, hence the odor.
Good Luck,
Ken
Old Jun 15, 2001 | 04:45 PM
Fire"Dutch"Bird's Avatar
Car: '88 Firebird Formula 350
Engine: 350 (5.7 TPI)
Transmission: auto 700R4
Axle/Gears: BW 9-bolt L.S.
Leaking filler neck, my gues!
When I run my tank 3/4 or more the smell is there,lower,no smell!
Old Jun 15, 2001 | 11:52 PM
BLUETA's Avatar
Car: 86 TRANSAM
Engine: 406
MINE SMELLED BAD TOO. I WOULD STOP AND LOOK FOR A FUEL LEAK ON THE INJECTOR RAIL FOR FEAR OF A FIRE. I FINALLY DECIDED THE RUBBER HOSES ATTACHING TO THE CHARCOL CANISTER WERE NOT TIGHT. I ADDED SOME FUEL LINE CLIPS TO THE LINES AT THE CANISTER, AND THE SMELL WENT AWAY.
HERS 90 IROC-Z 350 TPI
HIS 86 TRANSAM 305 TPI (406 AT SHOP NOW)
Old Jun 16, 2001 | 12:33 AM
89cam305's Avatar
I'm experiencing the same as Minn and Dutch. I've been trying to figure out what is causing the fuel odor. More noticable when the tank is over 1/2 full. Haven't checked the canister. Will have to take a look. I believe it's the filler neck however. The odor is noticable right by driver's side rear tire. I also have very little pressure when I release the gas cap.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
KCG
Jun 24, 2020 04:33 AM
86maro_252
Oct 10, 2015 06:52 PM
kx3g
Sep 28, 2015 08:14 AM
reactor60
Sep 22, 2015 01:44 PM
