Is 305 H.O. roller engine
Old Jan 3, 2005 | 08:21 PM
del91_305's Avatar
Car: 1991 camaro RS
Engine: 305 Carb
I was at the local performance shop today and they said that my engine is a hydrolic roller engine or something like that. Is it?
Old Jan 3, 2005 | 08:24 PM
deepstage69's Avatar
Car: '92 RS, '84 Z28
Engine: 383, L69
Transmission: T56, 700R4
Axle/Gears: 3.42, 3.42
The 5.0 HO aka L69 isnt a roller motor, but your LO3 is.
Old Jan 3, 2005 | 08:57 PM
vernw's Avatar
Car: 91 Formula WS6 (Black, T-Tops)
Engine: 383 MiniRam (529 HP, 519 TQ - DD2K)
Transmission: Built '97 T56, Pro 5.0, CF-DF
Axle/Gears: 4.11 posi Ford 9"
At least in the firebird, the 395 H.O. (dual cats) motor definitely WAS a hydraulic roller motor. Mine was!
Old Jan 3, 2005 | 09:13 PM
Grim Reaper's Avatar
Car: Death Mobile
Engine: 666 c.i.
Vern, first I think you had a typo and meant "305" and not "395". Second, if it's "dual cats", its the 90-92 TPI engine (LB9) which isn't the H.O. engine (aka L69). Though the 90-92 TPI LB9 was the most potent factory 305...it just isn't referred to as the "H.O."
To the poster, I am NOT certain when the last L69 was produced but the roller block didn't come out until 1987...and there are SOME documented cases of post 1987 SBCs which still are not roller blocks (mostly in trucks).
Old Jan 3, 2005 | 09:39 PM
vernw's Avatar
Thanks for the correction, Glenn. Yeah, it should have said "305"....
And as for the H.O. designation, you're probably right there, too. I've seen my old 305 referred to as the 305 HO since it was the "hotter" dual cats version, but they might have been the "unknowing" who did that.
Sorry for the improper info post!
Old Jan 3, 2005 | 10:11 PM
Car: Death Mobile
Engine: 666 c.i.
No need to apologize Vern. We are all here to learn and share info. What is more important, is that you DID have the most potent 305 car made (before you installed the 383). So there were no lies
PS: How's the 10 bolt and 5-speed holding up to your current torque monster?
Old Jan 3, 2005 | 10:12 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
That last HO (L69) was 1986 IIRC.
Old Jan 3, 2005 | 10:19 PM
vernw's Avatar
No problems so far. Of course, I use the clutch for every shift, and try not to abuse it TOO much......
Sometimes you just have to dump the clutch from a few extra RPMs and break both tires loose just to impress and listen to the sound and enjoy the feel ---- even if you are a 52 year old Old Phat Phart!!!!
That Ram Kevlar clutch sure grabs quick and holds on....
Definitely a FUN RIDE, and I'm still not done tuning it yet!
Old Jan 3, 2005 | 11:27 PM
blacksheep-1's Avatar
Car: 83 Z28
Engine: vortec 305 for now
Transmission: 5 speed
Excuse me..pardon me...
Would you happen to know the HP rating of the L03?
............Thanks
Old Jan 4, 2005 | 01:15 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
https://www.thirdgen.org/newdesign/tech/techdb.shtml
(This isn't crankiness, you see. This is simply a fishing lesson...)
Old Jan 4, 2005 | 01:17 AM
five7kid's Avatar
For the record: Every question posed in this thread could have been answered by looking at the information provided in the one link above.
Again, not crankiness, just fishing lessons...
Old Jan 4, 2005 | 05:21 AM
86Z's Avatar
86Z
Car: 1986 Camaro SC
Engine: 305 TPI Procharged D1SC
Transmission: Tremec TKO-600
Axle/Gears: Moser 12 Bolt 3.73 posi
Your query has found 1 match!
Here are your results:
LB9 : ENGINE, GAS, 8 CYL, 5.0L, TPI, HO
um my 305 is an "H.O"
Old Jan 4, 2005 | 01:35 PM
Benm109's Avatar
Car: 1991 Chevy Camaro
Engine: 305 TBI
............Thanks
I know five7kid posted the link, but here you go:
LO3 V8 9.3:1 5.0 (305) 170 HP@4000 RPM 255 TQ@2400 RPM TBI
Old Jan 4, 2005 | 05:28 PM
Car: Death Mobile
Engine: 666 c.i.
Nope, it is not. The description is wrong. LB9 TPI has never been "H.O." The L69 was the "H.O." engine.
Old Jan 4, 2005 | 05:35 PM
Air_Adam's Avatar
This is exactly the kind of thing that causes this misconception (sp?). The only engine you could have that would put HO badges on the car and was really called a 305 HO (or 5.0 HO) was the L69. The TPI was never the HO motor, even if it did have more advertised power than the L69.
Old Jan 4, 2005 | 07:26 PM
86Z's Avatar
86Z
Car: 1986 Camaro SC
i was told by the machine shop also that mine was an h.o due to the flat top pistons and higher compression, so tell me what makes an L69 an H.O compared to the LG4?
Old Jan 4, 2005 | 07:32 PM
five7kid's Avatar
https://www.thirdgen.org/techbb2/sho...hreadid=261488
86Z: Check your VIN. If it's an "H" (very, very likely), that's a lo-po LG4. If "G", a very, very rare '86 L69. You've done enough to yours (except I don't remember seeing exhaust mods) to make yours essentially as good as an L69.
When we say "search", we mean this Board, not the WWW.
Old Jan 5, 2005 | 02:26 PM
86Z's Avatar
86Z
Car: 1986 Camaro SC
of course my vin is an H but it's not the LG4 i swapped in a 88 tunedport 305 roller, what i meant is, basically the LG4 and L69 differences aside from the dual snorkel air cleaner and the other little things, was a bigger exhaust, flat top pistons and a higher lift cam, so what determines if a motor is a high output?
Air_Adam's Avatar
What makes an L69 an H.O compared to the LG4?
- Higher compression
- Better exhaust manifolds
- Better exhaust system
- Bigger cam
- More aggressive CC settings
- Better carb calibration
- Dual snorkel air cleaner
- Aluminum intake manifold
- Electric rad fan
Old Jan 5, 2005 | 04:20 PM
five7kid's Avatar
It's all in the conventions.
"HO", or "high output"? One is a decal, the other a goal.
GM also has crate motors they call "HO", as in 330HO (330 horse 350 with Vortec heads) aka 350HO, 454 HO and 502 HO. They used to have a kit called the "HO 350 Camaro Conversion Kit" that was based on a ZZ4 engine. They also have crate motors called "3.4 HT" and "HT 502" ("high torque") for what that's worth.
"Positrac", "Turbohydro", "Super Power Pack", "HO" - they're all marketing buzzwords that people latch onto as if significant.
But, if you claim your 305 is an "HO", you'd better have a VIN G.
Oh, the stereo in my '82 was called "ERS" for "Extended Range Stereo". None of it is the stock '82 stuff now, but the speakers and amp have better specs than the originals. Is it okay for me to leave the dash badge on there? Maybe I'd better take it off...
Jake_92RS
Jan 28, 2020 10:37 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
kyleb24
Aug 15, 2015 08:24 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
84z96L31vortec
Aug 10, 2015 08:27 PM
