Distributor help needed?
Old Jan 7, 2005 | 02:24 PM
seanjuan's Avatar
Car: 1981 monte carlo/sold 1984 z28
Engine: 350 w/carb no mods
Transmission: th 350 w/shift kit & 2800 stall
I just got an hei distributor that doesnt have the silver vacuum thing hanging out the side. Does that mean it is computer controlled? I cant use it if it is. thanks for the help.
Old Jan 7, 2005 | 02:44 PM
vernw's Avatar
Car: 91 Formula WS6 (Black, T-Tops)
Engine: 383 MiniRam (529 HP, 519 TQ - DD2K)
Transmission: Built '97 T56, Pro 5.0, CF-DF
Axle/Gears: 4.11 posi Ford 9"
Yep, should have a much smaller diameter cap as well. Then that would be the computer controlled version. PM me with details if you need to get rid of it, please.
Old Jan 7, 2005 | 02:53 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
Does it have a a terminal or 2 out the base or a small lead with a weatherpack connector coming out of it?
Old Jan 7, 2005 | 03:01 PM
seanjuan's Avatar
You dont mean that the distributor cap will be smaller do you? It looks normal size. I can double check when I get home to make sure. I gotta check the distributor again because there should be terminals going to have wires to hook up to the car's computer right? Im just po'ed that I gotta put the non cc distributor in because I heard that its a pain to line up correctly
Old Jan 7, 2005 | 03:09 PM
vernw's Avatar
One word of warning, I'm not sure which type of distributor you initially had, but if it was a vacuum advance distributor and this one is computer controlled, you won't be able to use it without totally replacing your wiring harness and computer to one designed for a computer controlled distr. set-up....
Old Jan 7, 2005 | 03:24 PM
seanjuan's Avatar
I think it's the stock distributor because my engine came with centerbolt heads, so I guess its 1987 or newer. I still havent checked the heads or block for numbers because its been so cold outside. When I got the car most of the computer's wiring was missing and the cumputer was gone too so Im swapping the compuer controlled carb and distributor and try to pass the emissions test.
Old Jan 7, 2005 | 03:42 PM
vernw's Avatar
Then you'll probably need a non-computer controlled distr with the vacuum advance since nothing can control the timing otherwise.
Old Jan 7, 2005 | 03:48 PM
seanjuan's Avatar
Is the vacuum davance the silver thing? I got an accel distributor with vacuum advance on it that I havent installed yet. The computer controlled distributor and carb are still on the car. Hope to swap them out asap!
Old Jan 7, 2005 | 03:54 PM
vernw's Avatar
Yep, the vac adv is the round silver disk about 1.5 " or so in diameter sticking out the side fo the distributor.
Good Luck!
Old Jan 7, 2005 | 04:04 PM
seanjuan's Avatar
Thanks I'll do a search for install tips for the accel HEI and get rid of the computer controlled carb and distributor.
IROCZ1989
Jan 24, 2016 03:55 PM
kitt23
Exterior Parts Wanted
Aug 15, 2015 12:37 PM
86camaroman201
Fabrication
Aug 11, 2015 10:39 PM
GEmrsn
Interior Parts Wanted
Aug 8, 2015 03:15 PM
tero
Aug 6, 2015 06:34 PM
