Help Me Make My Decesion
Old Jan 8, 2005 | 02:06 PM
FndmntlsOfPimpn's Avatar
Car: 87 Formula
Engine: 350 tpi
Axle/Gears: Stock 9 bolt
Ok so i recived an email from another 3rdgen member about a possible trade for my 67 camaro for a 87 gta that is slightly modded adn was wondering if anyone could tell me abotu how fast you think this car is
Its a 87 gta 5.7tpi 700r4 with a mild shift kit
The engine has a SLP 160* thermostat, SLP headers, high flow cat and SLP cat back exhaust, It also has SLP cold air induction, tpi throttle body airfoil, SLP siamesed runners and a manual fan switch
What do you think?
Old Jan 8, 2005 | 02:23 PM
TexasLT1's Avatar
Car: '92 RS
14.0 @ 98 ?
Old Jan 8, 2005 | 02:33 PM
z28kindaguy's Avatar
Car: 2004 Pontiac GTO
Transmission: M12
:werd:
Old Jan 8, 2005 | 02:41 PM
Car: 87 Formula
Engine: 350 tpi
what do you think i would ahve to do to get into the 12s with this car?
Old Jan 8, 2005 | 02:55 PM
CaptPicardsZ28's Avatar
Car: NCC-1701-D (docked in AZ)
Engine: impulse drive
Transmission: fusion reactors
Axle/Gears: Rescued from the Borg by my crew
Why would you trade your 67 camaro away for the 87? Is there something wrong with it? I am looking for a first gen to buy.
Old Jan 8, 2005 | 04:04 PM
Project's Avatar
Car: 85 Camaro Z28
Transmission: 700-R4
don't be stupid 1st gen are wayyy more collectable, moddedable in every aspect than 3rdgen.
If you get rid of that 67 we should ban you on grounds of you being retarded
Old Jan 8, 2005 | 04:09 PM
nick418's Avatar
Engine: L98, Hemi 6.2
:werd:
Old Jan 8, 2005 | 04:18 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
i would keep the 67
that 87 GTA should do 14.3's at 97-98ish. i have practically the same mods on mine except with some suspension work and 2800 stall and i am doing 13.9's. LOL
Old Jan 8, 2005 | 06:21 PM
megaracerx's Avatar
i think the 1st gen has no drive train..
Old Jan 8, 2005 | 07:08 PM
ME Leigh's Avatar
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
Pretty much replace or upgrade everything. The tranny isn't going to like it and there i now way TPI, will make it there. Or big power adders, but the tranny and rear won't like that much either.
Old Jan 8, 2005 | 08:45 PM
Car: 87 Formula
Engine: 350 tpi
the reson im trading my 67 is because i cant afford to build it and it needs quite a bit of work its a extremly good solid body but first gens are costly for a 17 year old kid to build
Old Jan 8, 2005 | 08:52 PM
Cooper's Avatar
Car: '89 GTA
Axle/Gears: 3.45
I'd still keep it, 20 years from now you'll be glad you did. Hell, 10 years from now you'll be glad you did. Trust me You're only 17, you've got tons of time to put into a '67 and they're only getting more collectable every day.
Old Jan 8, 2005 | 08:56 PM
Like I said...I am interested. How much you want for it? I dont care how much work it needs.
Old Jan 8, 2005 | 09:02 PM
bru333's Avatar
Car: 1987 Camaro SC
Engine: 2.8L MPFI (rebuilt)
Transmission: 700R4 swapped to T5
Axle/Gears: 3.42 open
A good condition first gen even without an drivetrain is worth a lot more than that 3rd gen.
:no: Don't get rid of it! You would regret it latter on.
Old Jan 8, 2005 | 10:43 PM
Car: 87 Formula
Engine: 350 tpi
Liek i said i cant afford to build the car right now and i liek 3rd gens just as much as first gens and they are so much affordable to build im tryin to get one put together for the spring of my senior year and to drive to prom and whatnot. in 10-20 years ill be able to afford to build a first gen im not very intersted in value at all i jus want to have what i want to have and how i want it. But untill i sell/trade my 67 im stuck driving this which is kinda hard to pick up the ladies in
Old Jan 8, 2005 | 11:10 PM
megaracerx's Avatar
what do you mean? that car is super sweet.
Old Jan 8, 2005 | 11:34 PM
Car: 87 Formula
Engine: 350 tpi
haha if only. Still trying to decide if i got this car i would have some money pretty soon to get some stuff done before spring. Ima throw a new paint job on it and do some engine mods. What do you think the first things i should do to the motor are? I like carbed motors alot more but i think that im gonna stick with a fuel injection setup what are the first things i should do? Can you still use normal aftermarket heads on these motors say if i wanted to put soem trick flow heads on it or somehting?
Old Jan 9, 2005 | 07:34 AM
greezemonkey's Avatar
Car: A Portly 85 Z28
Engine: 4.530 X 4.250 BBC
Transmission: under rated for this application
Axle/Gears: also under rated
Don`t you mean "stuck driving this witch"
Ya, I seen the picture of it you posted, looks like it needs everything cept,
1. roof panel
2. firewall
3. subframe
4. spare tires
I`d take the gta if it were at least an 8 outta 10 car, but you will regret getting rid of that first gen one day
Old Jan 9, 2005 | 07:54 AM
smithtc's Avatar
I'll take a stab: If you like the TPI
Drag Radials
LPE 74211 Camshaft
Ported intake and plenum
Aftermarket runners (LPE, AS&M)
Better heads (Upgraded Vortecs with Vortec manifold; AFR 180s; Canfields, Ported 083s (which come on the car), etc. Normal aftermarket heads work)
Stall converter to match camshaft
If the rear and trans. hold, and it's all "tuned" well, you should be doing solid 12s.
Just one option. There are others. More possibilities if you swap intakes for Holley Stealth Ram, LT1 conversion, Mini-Ram, etc.)
Old Jan 9, 2005 | 09:26 AM
Car: 87 Formula
Engine: 350 tpi
can you put normal aftermarket aluminim 350 heads on thse motors? or do tpi cars require certin heads?
Old Jan 9, 2005 | 10:20 AM
smithtc's Avatar
Yes.
There are some minor issues with the intake bolt "slots" and perimeter bolt versus center bolt valve covers, but other than that any Gen I small block head should bolt right on to your short block with no problems. I don't recall any other issues.
Old Jan 9, 2005 | 10:23 AM
Car: 87 Formula
Engine: 350 tpi
im debating on if i get the car i should stick with tpi or go to carb. but since i dont even have the car yet i think ill wait to decide all this. Thanks for all the help guys:hail:
Old Jan 9, 2005 | 12:17 PM
urbanhunter44's Avatar
Car: '72 Chevy Nova
Engine: Solid roller 355
Transmission: TH350
Axle/Gears: 8.5" 10-bolt 3.73 Posi
It's up to you, BUT YOU WILL REGRET SELLING THE FIRST GEN!
Old Jan 21, 2005 | 04:21 PM
Dan8289gta's Avatar
Car: 89 GTA
Engine: 350 tpi
Keep the camaro save up a couple grand and by a decent 3rd gen theyre not very hard to come by i got my 89 gta 1 owner 67,000 original miles for under 3 grand, i did look around constantly for about 5-6 months but it was worth the wait.
DONT TRADE THE CAMARO THESE GUYS ARE RIGHT YOU WILL REGRET IT AND MAY NEVER HAVE THE OPPORTUNITY AT ANOTHER ONE IN THE FUTURE.
Bubbajones_ya
Aug 31, 2015 12:02 PM
lt1z350
Aug 28, 2015 05:57 AM
86White_T/A305
Aug 17, 2015 12:16 AM
mustangman65_79
Aug 11, 2015 03:17 PM
z28addict8490
Aug 7, 2015 08:48 PM
