random missing and pinging
Old Jan 8, 2005 | 02:28 PM
ajl'86T/A's Avatar
Car: 1986 T/A
Engine: 5.0 carb
Transmission: 700-R
I just replaced teh plugs in my T/A and it misses at idle speed. Im positive that i gapped them right and are the right plugs. im wondering if its some emissions crap. It also does some other things that may be related, like pinging at normal operating temp, and it has some hesitation at wot. The idle speed is weird too; it idles at like 700 out of gear when cold, and 1000 when its warm. I dunno, its weird an ne 1 help? i looked and there wasnt nething like this
Old Jan 8, 2005 | 02:45 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
Firing order correct?
Old Jan 8, 2005 | 02:46 PM
hellfire's Avatar
Car: 91 Firebird
Engine: 305 tbi
Transmission: manual
the only thing you did was replace the plugs? i would then check for possible damage to the wires.
Old Jan 8, 2005 | 02:51 PM
ajl'86T/A's Avatar
Car: 1986 T/A
Engine: 5.0 carb
Transmission: 700-R
yes, the firing order is correct, its only after the car has been idling for about 10sec out of gear. and only when warm
Old Jan 8, 2005 | 03:17 PM
bru333's Avatar
Car: 1987 Camaro SC
Engine: 2.8L MPFI (rebuilt)
Transmission: 700R4 swapped to T5
Axle/Gears: 3.42 open
How old is the rest of your ignition system? Coil? Ign. control mod.? Pickup coil?
edit: Here is another member with a similar problem:
https://www.thirdgen.org/techbb2/sho...hreadid=258614
Old Jan 9, 2005 | 10:47 AM
ajl'86T/A's Avatar
Car: 1986 T/A
Engine: 5.0 carb
Transmission: 700-R
the rest of my ignition system is stock from '86 except the wires which I replaced last year. Could that really have something to do with it bieng that it idled fins b4 i replaced the plugs? The only problem i had b4 i replaced the plugs was a bad mis under load, and less low end power, but now all that is fine, it just misses at idle.
Old Jan 9, 2005 | 10:58 AM
Red Devil's Avatar
Car: Tree Huggers
Engine: Do Not
Transmission: Appreciate Me.
What kind of plugs/ wires? What condition is your cap and rotor in? Did you test the resistance in the wires yet? Have you tried swapping back to the old stuff to remove the plugs/wires from the equation?
Fanatic1074
Oct 3, 2022 05:57 AM
RS Reaper
Oct 17, 2018 07:52 PM
BrianI
Oct 3, 2015 12:57 PM
ndndndnd
Sep 28, 2015 08:00 AM
