I'm very confused
Old Jun 17, 2001 | 11:38 PM
mattsamazing's Avatar
I'm very confused
I have an 89 rs. Tonight I drove it to the grocery store, normal driving not hard or anything. Park and when I get back the car won't start. The battery was working cause the stereo came on but no noise from the starter whatsoever. I pop hood take a look and see nothing wrong. Then I sit in the car looking for a quarter to call home 3 minutes later I try starting it again and if fires up. What would have cause it not to start? Sorry for the long post.
Old Jun 17, 2001 | 11:54 PM
One Eyed Jack's Avatar
I had the exact same thing happen to me.
Does your ignition key have a resistor on it?
A little rectangular black piece with a metal line inside the key?
Yeah make sure thats cleaned off.
Dust off the ignition with a woman's makeup brush (unused of course).
While you're at it use that brush to clean your air vents.
Remember, NO WD-40 IN THE IGNITION!
1992 Pontiac Firebird (stock)
- 305ci V8 TBI / Automatic Trans / Every option, excluding leather
- Killer car audio system:
  • Aiwa CDC-MP3 head unit
  • Rockford Fosgate 360a2 amp
  • pair of 12" MTX Thunder 5000s in a custom box
  • Pioneer 3-way 6x9s, soon to add more more more!
Old Jun 18, 2001 | 12:52 AM
NCZ28's Avatar
It could be a sign of the starter and/or solenoid going bad. Mine wouldn't turn over once in a parking lot, but it started right up after we pushed it off the rollback at my house. I put a new starter on, and I've had no problems since. I would also check to see if the battery cables are corroded.
Old Jun 18, 2001 | 02:10 AM
Enkil's Avatar
If it's an 89, most likely it does have that little nugged in the key. A lot of people seem to have problem with it after a while (known as VATS). Try cleaning it off with some rubbing alcohol, and drying it before you put it back in your car. Search the boards, there's plenty of much better posts than this one about this subject.
89 iroc-z 305 tbi
k&n filtercharger, open element air filter. nuffin' else
Old Jun 18, 2001 | 08:18 PM
I'll check out the ignition key and battery. Thanks for the ideas guys.
Galaxie500XL
Feb 1, 2020 04:53 AM
Jorlain
Oct 8, 2015 01:57 AM
sahlomonic
Sep 20, 2015 07:15 PM
bubbaz28
Sep 18, 2015 02:09 PM
Denricci22
Sep 18, 2015 09:02 AM
