mixture control selenoid
Old Jun 18, 2001 | 01:59 AM
z28onTweenkies's Avatar
Car: 1992 Camaro Z28 & 2k3 Cadillac CTS
Engine: LB9
Axle/Gears: 3:43
I have no idea how to replace the mixture control selenoid, but no matter what i do my car seems to still run rich. i'm going to change my oxygen sensor, but how much would it cost to also change my mixture control selenoid? how much work would i be getting myself into? thanks
Old Jun 18, 2001 | 02:00 AM
Engine: LB9
Axle/Gears: 3:43
oh yeah, its an 87 z28 305 rochester 4 barrel with 113k
Old Jun 18, 2001 | 02:19 AM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
If you hear it "ticking" when you roll the key forward w/ out starting the engine, it's not the M/C solenoid.
Do you have the Q-jet tools and gauges to adjust rich & lean stops?
Did it ever run right before?
jmd
L69 / T5
Old Jun 18, 2001 | 10:29 PM
Engine: LB9
Axle/Gears: 3:43
no i dont have the q jet tools and gauges, and i do hear the ticking when i put the key to the on position. it is running rich, are the tools very easy to find? how much can i expect to pay? thanks
Old Jun 19, 2001 | 03:40 AM
formula90's Avatar
Car: 1990 Formula
Engine: 5.7 liter
To get to the M/C solinoid you have to take the airhorn off the carburator, after that, unscrew the one screw that holds it in and carefully lift out the metering rods and gently slide it up and out. puttin that carb together right with the TPS stayin in will be a beeeaach. My suggestion would be to go to your local parts house and buy the haynes rochester quadrajet book. it has step by step on how to do it correctly using a carb stand and such...that is how I learned and I also learned alot about how it works doing it. after puttin it back together, if you have more than 10 extra screws, well....your S.O.L. good luck
<font face="Verdana, Arial" size="2">I have experience......unfortunatly its a result of bad judgement......</font>
click below to check out....
www.formula350.com
or click below to email me
webmaster@formula350.com
thunder57
Nov 7, 2015 02:28 PM
tmellott89
Oct 14, 2015 02:06 PM
Briandrex
Oct 5, 2015 06:20 AM
tattmann
Sep 27, 2015 05:20 PM
Damon
Sep 26, 2015 04:29 PM
