starter wont even click anymore.....
Old Jan 11, 2005 | 02:22 PM
FireRed91Z28's Avatar
Car: 91 Z28
Engine: currently 350...BUILT 383 soon
Transmission: T56 w/4.10's
i bought another 91 Z to use as my daily driver seein as my current 91 is getting a fresh TT motor put in and this new car sat for a while and it wont even start. the batt is new Optima red cap fully charged, when i turn the key into accessory mode everything works. then when i turn to start the car the starter would just click and not crank over the engine (its a 350 TPI w/ T56 all worked fine when the car was bought but i left it sittin for a while over some cold months) i kept trying to start it, even tried jumping but now the starter doesnt even click, there is still power to all the accessories but nothing from the starter??? what happened?
Old Jan 11, 2005 | 02:28 PM
Token's Avatar
Car: 1992 Firebird
Engine: forged 357
Transmission: 700r4, 2200-2400 stall, vette servo
Axle/Gears: stock pegleg 2.73 drum (temp)
Is your fuel pump priming? Potential VATS trouble?
Old Jan 11, 2005 | 02:31 PM
ME Leigh's Avatar
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
Sounds like bad electrical connections. It is best to connect a large ground cable directly from the battery to the engine block.
Old Jan 11, 2005 | 02:57 PM
91Z28-350's Avatar
Check the trigger voltage (purple wire) on the starter. If it's low, check the voltage coming out of the starter relay. If that's fine, check the voltage at the neutral safety switch on the clutch pedal.
Old Jan 11, 2005 | 03:03 PM
Token's Avatar
Car: 1992 Firebird
Engine: forged 357
I've been through that before
Trickster knows all.
Old Jan 11, 2005 | 03:12 PM
91Z28-350's Avatar
Sorry, but you lost me with that.
Old Jan 11, 2005 | 03:16 PM
Token's Avatar
Car: 1992 Firebird
Engine: forged 357
Trickster, highly regarded member of this forum, he has helped me out of every single electrical dilemma I've ever had.
Old Jan 13, 2005 | 07:37 AM
gonzo1028's Avatar
ok dumb question?
can you turn the engine over by hand? Hope it's not locked up.
If it is free , I am thinking it sounds like the ignition switch may be suspect.
I other thing, is the brake lights coming on when applying the brakes? Possible a bad brake switch or possibly even a neutral safety switch.
3rd gen money
Oct 11, 2019 09:57 PM
RS Reaper
Oct 17, 2018 07:52 PM
Linson
Oct 1, 2015 09:50 PM
SS-EXPRESS
Sep 28, 2015 09:14 AM
