cam question
Old Jan 14, 2005 | 01:00 AM
Mr. Brett's Avatar
Car: 1989 Camaro IROC-Z
Engine: 5.7 TPI
cam question
I'm in the process of rebuilding the 5.7 TPI in an '89 Iroc and need to replace the cam. This car is only a daily driver, so I'm just looking to get it in good running order, not necessarily make a lot of extra power. What are my cam options with a stock ECM? I don't mind putting a beefy cam in it as long as the stock ECM can run it. What would you guys recommend, keeping in mind that this is being done on a tight budget? I've checked Summit, Jegs, etc, and I really can't afford to spend $500+ on a cam package. I'm just looking for something comparable to the stock specs. Thanks!
Old Jan 14, 2005 | 08:01 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Try this one Only other thing you really need to change is the valve springs. Use Comp 981 springs.
Old Jan 14, 2005 | 11:57 AM
Mr. Brett's Avatar
Engine: 5.7 TPI
Ok, I've got the opportunity to buy an entire cam setup from an LT1 REALLY cheap. How well will this work in my '89 5.7 TPI? Are the specs close enough between the two cams that it will be alright? Like I said before, I'm not really looking for huge power gains or anything. I just want to keep it pretty close to stock so I can run it (at least temporarily) on a stock ECM. Any thoughts?
Old Jan 14, 2005 | 12:19 PM
91wtROH17's's Avatar
Car: 91Z
Engine: 355/afr/sr/lpe219
Transmission: built 700R
You will really just be wasting time by swapping the LT1 cam in. It almost too close to the L98 cam to notice any diff. Go with RB on this one.
Old Jan 14, 2005 | 12:27 PM
Streetiron85's Avatar
Car: '85 IROC
Engine: LB9
Transmission: 700 R4
The ZZ4 cam is a step above the L98, and they can be found new on ebay for $120- $135 regularly.
I've heard also that Sallee Chevrolet sells them for $100.
It's milder than the Comp cam posted earlier.
Old Jan 14, 2005 | 04:32 PM
Mr. Brett's Avatar
Engine: 5.7 TPI
What lifters would you recommend with the ZZ4 cam? And can I run it with stock springs and rocker arms?
Old Jan 14, 2005 | 04:45 PM
ME Leigh's Avatar
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
Stock hydraulic roller lifters, i wouldn't run any cam with the stock springs. There was some place where you could get a new LT1 cam for $50. But i can't find it now, or maybe i'm just on crack, i'm leaning towards the latter.
beastin91rs
Oct 9, 2015 07:38 AM
SLNTSCPE
Aug 22, 2015 09:15 PM
theurge
Aug 21, 2015 12:46 PM
redmaroz
Aug 16, 2015 11:40 PM
Fronzizzle
Aug 9, 2015 01:15 PM
