Starter for LG4 700R4?
Old Jan 17, 2005 | 06:23 PM
phess11's Avatar
Car: 83 Z28
Engine: 305 (LG4)
Transmission: THM700R4
Axle/Gears: 10 bolt, 3.23 non-LS
I looking into a mini starter to replace my original Delco Starter.
1. With an 1983 LG4 and a 700R4 do I have 153 or 168 teeth?
2. Any starter recommendations?
thanks,
phil
Old Jan 17, 2005 | 07:28 PM
onebinky's Avatar
153 tooth
Old Jan 17, 2005 | 07:49 PM
thirdgen88's Avatar
Car: 1995 Corvette
Transmission: 6 spd Manual
Axle/Gears: Dana 44, 3:45:1
A starter from about a '95 LT1 works real good.. I have one in my GTA, and its small and gets the job done, without costing a bunch of money - ~$115
Old Jan 17, 2005 | 08:59 PM
phess11's Avatar
Car: 83 Z28
Engine: 305 (LG4)
I assume that is a GM starter for the 95 LT1? Do you have a part number? Will the bolts match the holes in my block?
Old Jan 17, 2005 | 09:28 PM
thirdgen88's Avatar
Car: 1995 Corvette
Yeah, you can get them at any parts store (I got mine at advance)... An alternative would be an actual gear-reduction mini-starter (also available at Advance Auto Parts - ask for part number 3510GRHBK)...
Yes, it should go just fine on your block (I'm using one on my 1991 L98, it uses the straight across pattern for the 153 tooth flexplate)...
Old Jan 19, 2005 | 07:14 AM
phess11's Avatar
Car: 83 Z28
Engine: 305 (LG4)
I have somewhat narrowed it down to the following:
Powermaster 9000 or the
Magnum 3510GRHBK
any quality issues between the 2.
thanks,
phil
Old Jan 19, 2005 | 11:12 AM
Damon's Avatar
The 95 LT-1 mini-starter IS a gear reduction type starter, FYI. Used one for the first time on my wife's 92 RS and it seems to work just fine.
Old Jan 19, 2005 | 12:40 PM
phess11's Avatar
Car: 83 Z28
Engine: 305 (LG4)
I guess I need more infor on the 95 LT-1 mini-starter. I assume it is a Delco starter. When I look at AdvanceAuto online for a 95 Camaro starter the Delco units are over $200. I have been told they should be around $120. Can someone point me to part number or something that I can make sure I get the correct thing. I guess I am just :werd:
thanks,
phil
Old Jan 19, 2005 | 08:00 PM
Damon's Avatar
The rebuilds at the local parts stores are more like $125-135. A new Delco unit is almost certainly around 2 bills.
Old Jan 19, 2005 | 10:48 PM
Goumba T's Avatar
Car: 1990 TA
Engine: LB9 305
Transmission: 4L60
Hell and people tell me stores in NY are ripoffs.
I got a AC rebuilt unit a week ago and it cost me $44 at a local auto parts store.
Old Jan 20, 2005 | 12:20 AM
thirdgen88's Avatar
Car: 1995 Corvette
We're not talking about the standard starter for his car, we're talking about the mini-starters.
Advance Auto:
Palladium P6470S - $122
Granted, I guess you need a core for that one...
Old Jan 21, 2005 | 07:52 AM
phess11's Avatar
Car: 83 Z28
Engine: 305 (LG4)
After doing a bunch of searching, will I have a battery/other cable length issue if I am going from a stock 83 LG4 starter to a summit mini-starter?
If so, what are the recommendations to solve "correctly"? Is there enough slack?
thanks,
phil
Old Jan 21, 2005 | 08:30 AM
thirdgen88's Avatar
Car: 1995 Corvette
I was able to make the battery cable fit.. I did have to release one of the frame brackets to get a little extra length, but no big problem..
Old Jan 21, 2005 | 09:23 AM
phess11's Avatar
Car: 83 Z28
Engine: 305 (LG4)
thanks for the response.
Old Jan 21, 2005 | 11:42 AM
Goumba T's Avatar
Car: 1990 TA
Engine: LB9 305
Transmission: 4L60
My mistake. So am I correct in assuming they just bolt right in? I had heard of using the LT1 starters, but I needed mine right away so I ended up just getting the stock type - I didn't know what else I'd need. However for that amount I'll sell the starter I just bought if the LT1 a direct fit.
Old Jan 21, 2005 | 02:57 PM
thirdgen88's Avatar
Car: 1995 Corvette
No modification needed except for what I said above (undoing one cable mounting bracket to get about another 1.5 inches of positive cable movement)...
loud91rs
Oct 5, 2015 10:05 PM
92projectcamaro
Sep 29, 2015 07:07 PM
IROC ZELLER
Sep 29, 2015 03:00 PM
SS-EXPRESS
Sep 28, 2015 09:14 AM
6998poncho
Sep 25, 2015 02:56 PM
