Hey Vader I got a Question?
Old Jun 20, 2001 | 08:45 PM
West Coast GTA Man's Avatar
Car: 1989 Pontiac GTA Hardtop.
Engine: ZZ4 - 350
Transmission: Garbage
Hey man, I noticed in your response to the post "Operating Temperatures" That you had a picture of your car with a larger new front air deflector. I was wondering where you purchased that, and was it easily installed. I have noticed that my car has been running up to about 235 degrees, and that when I checked my air deflector under the front bumper, only the front middle section is there. Both the curved sides are missing. This could be a small amount of my problem.
Thanks for your help man!
See ya
Mike
Smokin 1989 GTA- Bone stock except for exhaust. (no catalytic-stainless pipe into Flowmaster 2 chamber).
Old Jun 20, 2001 | 09:16 PM
Xenodrgn's Avatar
(hope your not mad that I answered this before you did.)
Just the middle section is all stock is supposed to have... What Vader did was he went out to local garden supply store and bought that black plastic garden divider stuff. It's cheap, and it only takes a sharp knife to cut, and you can easily screw it on using factory holes and screws...
Unless I was dreaming when I read that post, I believe thats what he did... vader, wanna ditto what I said or slap me?
1985 Camaro SC - 2.8L, auto.
Mods:
Removed air baffles, mandrel bent cat-back pipes (but stock replacment muffler, Dynomax Turbo and Catco converter are on thier way)
Old Jun 20, 2001 | 09:51 PM
ede's Avatar
ede
i made one out of an aluminum kick plate for a entry door, looks good and it's shiney, if you like shiney. i'm not vader either so i'm sorry if this response offends you in any way. vader ought to wander along here before long to answer your question.
ICON Motorsports
1st & 3rd
MM Black Diamond 538 F&AM
Old Jun 20, 2001 | 11:15 PM
Guest
Guest
Posts: n/a
<font face="Verdana, Arial" size="2">Originally posted by Xenodrgn:
</font>
Not on a Firebird, it goes all the way to the sides.
There are 2 different ones is my understanding... one is a one piece deal, and I think its been replaced by the newer 3 piece deal. Stuff is cheap from the dealer, tho I dont think it will help cooling much.
Old Jun 20, 2001 | 11:36 PM
Kevin Irving's Avatar
Car: 1985 Trans Am
The air deflector comes as a 3 piece set for the Trans Am with the 85-90 nose. The Firebirds don't have the "fender extensions" to support the two outer pieces. I think I paid like 25 dollars a few years ago at the dealer for all three sections.
Kevin Irving
85 Trans Am WS-6, 305 TPI, custom burned '86 PROM with '87 "165"ECM, Accel Supercoil & 8.8 Wires, Rapidfire #2 @ .055", MSD 6AL, 1.6:1 Roller tipped rockers, Homemade AFPR, K&N cone, no airbox, Aluminum Driveshaft, Wonderbar, TB Coolant Bypass, Ported Plenum, Descreened MAF, Syclone Fuel Pump, JET Airfoil, Mobil 1 synth in all but transmission.
http://www.geocities.com/transam85tpi/
Old Jun 20, 2001 | 11:47 PM
Xenodrgn's Avatar
<font face="Verdana, Arial" size="2">Originally posted by madmax:
[B] Not on a Firebird, it goes all the way to the sides.
[B]</font>
My bad... sorry
Mods:
Old Jun 21, 2001 | 06:34 AM
Engine: ZZ4 - 350
Thanks Guys, I will check the prices at the dealer, and if it is astronomically priced, I guess I can make one.
Thanks again
Mike
Old Jun 21, 2001 | 09:49 AM
Guest
Guest
Posts: n/a
Well from the factory a Firebird has an airdam that runs all the way to the sides as well, there is something under there to hook it up to but its been so long since I owned the car I dont remember what exactly it mounted to under there. I cant see why the 3 piece wont work on a Firebird unless there is something you know that I dont (like you tried it... I havent had the 3 piece in my hands yet). The 3 piece is a replacement for the one piece that was originally used on at least 85-87 TA's.
25 bucks... told ya it was cheap
Old Jun 21, 2001 | 04:44 PM
Car: 1985 Trans Am
Well from the factory a Firebird has an airdam that runs all the way to the sides as well, there is something under there to hook it up to...... The 3 piece is a replacement for the one piece that was originally used on at least 85-87 TA's.
</font>
Cool.... thanks Max. I have no idea what the thing would be able to be fastened to on a Firebird.... on the T/As that fender extension is huge.... allowing for the 3 fasteners for the rest of the air deflector. I just wish they were'nt made of that soft plastic, the holes for the inserts rip out too easy.
Old Jun 21, 2001 | 10:42 PM
Vader's Avatar
Well, it's not exactly lawn edging plastic. It's a 1/4" thick 'V' ribbed closed-cell EPDM/vinyl compound so that it can flex without cracking and wearing, and is still rigid enough to stay in the wind at triple-digit speeds. I hadn't thought of the lawn edging idea, but I guess it would work if you didn't mind the scraping and scrubbing over those low approaches.
There is the original three-piece ABS plastic deflector set mounted behind the rubber, and made a convenient place to attach the rubber sheet.
The decorative side air skirts that the factory installed have little value in original form, so mine got "lowered" in the same manner. (The original can be seen as a comparison to the truly functional pieces.)
Later,
Vader
"Let the bodies hit the floor!"
Adobe Acrobat Reader
Old Jun 21, 2001 | 10:50 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
Vader, I've a question for ya,
DOesn't your wife get pissed at you for grabbing the digita camera and running out and taking pic's of your car all the time? I figure you must do it 6 or 8 times a night
Old Jun 21, 2001 | 11:10 PM
Guest
Guest
Posts: n/a
Kevin, I know... I own a TA. One side is fine, the other is pretty messed up... need a new gfx piece on that side, figure I'll replace both while I'm there.
As for the Firebirds, my rusty memory says theres a plastic piece there that attaches to the bottom of the bumper similar to the TA setup... and... I cant remember I do remember it was just black plastic. I'll have to look at a Firebird to refresh my memory.
Old Jun 21, 2001 | 11:34 PM
Xenodrgn's Avatar
<font face="Verdana, Arial" size="2">Originally posted by Vader:
</font>
Doh... my bad... it must have been someone else that did the lawn edging stuff...
Mods:
Old Jun 22, 2001 | 06:44 AM
Engine: ZZ4 - 350
Hey Vader, thanks for the pictures. that's a great Idea, and Looks great! The sides give it a slight lowered look. Now I have some Ideas.
Thanks again
Mike
MustangBeater20
Oct 29, 2022 09:20 PM
Lmancha96
South Central Region
Oct 22, 2020 12:40 PM
Red iroc-z 305
Sep 30, 2015 05:22 PM
1992Vortec
Aug 31, 2015 08:05 PM
squiggy2
Aug 9, 2015 09:30 PM
