AC Delete pulleys & Smog Pump Delete pulleys
Old Jan 21, 2005 | 01:01 AM
I-Roc with my Z's Avatar
Car: 1989 Iroc_Z
Anyone have a link or know where I can find these pulleys for a 89 camaro?
Old Jan 21, 2005 | 01:42 AM
BADASS91B4C's Avatar
Car: 1991 B4C, 1992 RS
Engine: 355, 305
Transmission: 700r4, 700r4
Axle/Gears: 3.73, ?
i would also like to know the part #'s for these, so i can go get them at the gm dealership. you can just take off the smog pump and route the belt different but i think it would look cleaner with pulleys personally
Old Jan 21, 2005 | 02:03 AM
robleamy's Avatar
Car: 92 z28
ac delete pully pn 10055890 gmpartsdirect.com
Old Jan 21, 2005 | 02:05 AM
Engine: 355, 305
Axle/Gears: 3.73, ?
thanks for the part# is there one for the smog pulley or is that not a gm factory part?
Old Jan 21, 2005 | 02:07 AM
Engine: 355, 305
Axle/Gears: 3.73, ?
sorry to hi-jack your thread but is there a part # for the non a/c heater box too? thanks
Old Jan 21, 2005 | 02:08 AM
robleamy's Avatar
Car: 92 z28
10186167 is the air pump pully number
Old Jan 21, 2005 | 02:39 AM
Engine: 355, 305
Axle/Gears: 3.73, ?
it comes up as a water pump pulley u sure thats the right part #
Old Jan 21, 2005 | 03:58 AM
transporter's Avatar
Car: 92 Z28
Engine: 305 TPI, Edelbrock headers, 3in Flowmaster exhaust
Check ebay. Got my pulley for $35.00.
Old Jan 21, 2005 | 04:04 AM
bru333's Avatar
Car: 1987 Camaro SC
Engine: 2.8L MPFI (rebuilt)
Transmission: 700R4 swapped to T5
Axle/Gears: 3.42 open
They call it a water pump pulley because it is used to keep the water pump turning the right way.
Old Jan 21, 2005 | 04:10 AM
Engine: 355, 305
Axle/Gears: 3.73, ?
ok thanks for all the info
Old Jan 21, 2005 | 02:42 PM
mdricken's Avatar
Car: 92 Camaro
Engine: ZZ4 Crate Engine w/Hot Cam
Transmission: Rebuilt 700R4 with Transgo and MW 3
Axle/Gears: 3.73 Eaton Posi
I dont know what your situation is, but a cheaper solution to delete the smog pump and/or a/c is to find a different serpentine belt and route it differently.
Somewhere on this site it describles how to route the belt to do this and what belt # to get (do a search maybe).
Old Jan 21, 2005 | 03:19 PM
Engine: 355, 305
Axle/Gears: 3.73, ?
its in a tech article on the main page of this site but i wanted to go with pulleys cause i think it will look cleaner
Old Jan 21, 2005 | 03:34 PM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
To get rid of the smog pump all it looks like you do is get a shorter belt since it is routed to the outside of the smog pump pulley.
I just did the A/C delete pulley on my 88.
evilstuie
Jan 9, 2020 08:29 PM
italiano67
Dec 11, 2016 09:21 AM
LittleFranks
Sep 17, 2015 12:22 PM
BlackphantomZ28
Aug 21, 2015 07:12 PM
actionj
Carburetors
Aug 16, 2015 09:51 AM
