fuel pump lobe.
Car: 90 RS, 83 z28, 85 ranger
Engine: none, 350, 2.8
Transmission: none, t-5, 5-speed
fuel pump lobe.
Is there any way to tell if i have a fuel pump lobe on my cam with out pulling the cam to see. or can i just take the block off plate and look. any help is greatful.
Car: 1995 Corvette
Transmission: 6 spd Manual
Axle/Gears: Dana 44, 3:45:1
You should be able to see with the block off plate removed... If it is a stock thirdgen cam, it will have the mechanical fuel pump lobe..
Car: 1995 Corvette
They didn't start getting rid of the fuel pump lobe until later model engines... can't remember when, searching might reveal something..
well if it don't have one i'll figure something out to get fuel to it. I don't really want to run and electric pump but if i have to i will. I can't stand the noist that aftermarket pumps make. I guess if all else fails i will get a better cam and make sure it has one on it. thanks for the help.
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
Just stick something up there like a wooden dowel and push it up until you hit the cam. Use a starter interrupt switch or have a friend bump it over. If you feel the dowel move, you have a FP eccentric. If you don't feel it move, you don't have an eccentric.
And you can't hear the pump if you have a good exhaust.
Originally posted by Stekman
good exhaust.
good exhaust.
Car: Z28
Engine: Sb2.2 406
Originally posted by scubas_90rs
and what is that. i have heard of it before but my car has never seen it before. my exhaust consists of a y pipe and that is it. the car never seemed to like having exhaust. put a few systems on it and it just keeps saying no i don't want them.
well all the aftermarket pumps i have heard are loud as hell. i wish i didn't have to pull the motor and put it into a different car. damn ditchs just jump out of nowhere and try to eat my car. oh well i am lucky i am still here.
beachrodder
Aug 25, 2015 08:05 AM
92camaroJoe
Aug 13, 2015 06:07 AM
