Would like some input on my New Setup....
Old Feb 6, 2005 | 12:38 AM
NEEDforSPEED's Avatar
Fresh 2000 5.7 vortec, 2-bolt main - stock everything,
LT1 intake, port match to the heads,
No EGR, either 24lb or 28lb injectors,
Rebuilt 5.7 "083 casting" TPI heads 3 angle valve job, Gasket matched, bowl work, mildly ported and exhaust fully polished, what compression ratio should i go with
When i look into head gaskets?
94 Camaro LT1 stock cam shaft, with 1.6 roller rockers... i don't think i can go over .480? my pick of heads have limitations, can i run stock springs? and im not quite sure what the lift is on the lt1 cams many websites list them differently,
shorty headers, 3" piping, y-pipe - back, no A.I.R or emissions, probably run no cat either,
a really good better then stock ram air with a good breathing air filter,
Rebuilt 700r4 with shift kit, witch stall?
Aluminum drive shaft, 3.27, limited slip poise, What HP and TQ numbers can i see with this type of set up at the rear wheels?
way later on plane on running a turbo,
but for now this is my current setup i already have most of the parts,
cheesehomer
Dec 31, 2015 08:48 AM
Linson
Oct 1, 2015 09:50 PM
83ho87gn
Sep 26, 2015 08:49 PM
83ho87gn
Sep 24, 2015 08:58 AM
83 Crossfire TA
Sep 18, 2015 12:01 PM
