New car, some problems..
Old Feb 9, 2005 | 07:40 PM
undead_undead's Avatar
Car: 1991 Camaro RS; 67,000 org. miles.
Engine: 305 L03 TBI
i just picked up a 91' RS with 64,000 original miles on it. it had some small leaks, which were repaired. i switched her over to synthetic 5w30 and i got some really loud ticking from the motor; so i went back to 10w30 dino and started it up, the noise was there for a minute and then went away. but now it's back and driving me nuts! also, does anyone have any idea where the fuel pump relay on my car is? i need to replace it as the pump is not priming anymore. anyones input is great appreciated!
Old Feb 9, 2005 | 09:56 PM
anondude13's Avatar
Re: New car, some problems..
What does your oil pressure guage read?
Old Feb 9, 2005 | 10:12 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Re: Re: New car, some problems..
Better yet... get a mechanical oil pressure guage (about $5) and tell us what that reads. The stock guage is notoriously inaccurate.
Old Feb 9, 2005 | 10:24 PM
anondude13's Avatar
Re: Re: Re: New car, some problems..
That's true, and if his guage is reading low, that would shut off the fuel pump. So I'd recommend doing both but it's easier to check the guage.
Old Feb 10, 2005 | 12:18 AM
Dynodan's Avatar
Car: 1992 firebird
Engine: 305tbi
The fuel relay is located on the firewall drivers side right behind the master cyclinder. There should be 2 if I am correct. The one closer to your passenger seazt is the fuel relay . You can swap the relays to test it before you by a new one. The other one is for your fan .
Dynodan
Frozer!!!
Jan 19, 2024 04:55 PM
Reddeath210
Oct 6, 2015 08:20 AM
Linson
Aug 21, 2015 02:12 PM
kyleb24
Aug 15, 2015 08:24 AM
bryan623
Aug 10, 2015 11:33 AM
