Charcoal canister...do I need it??
Old Jun 26, 2001 | 04:31 PM
1BadGTA's Avatar
Car: 1989 Trans Am GTA
Engine: 5.7 Liter
I lack this canister due to having cold-air (which leaves no room to put the canister). The hose that conected to the canister emits gas fuels badly and I can hear gas "bubbling" when the car is turned off and I open the hood. What should I do? Plug the hose, or just try and find a spot to put the canister. It's pretty tight under the hood. Any input is appreciated.
Chris
Old Jun 26, 2001 | 05:00 PM
mtx28's Avatar
check the tech articles, i think there is one on how to remove it, right.
  • 83 Z28-- not a pretty site to look at, 200k miles and im sure it was treated like a rental car every day of its sad life(before i got it).. sold, thank the lord
  • 74 Z28-- 383/400, green on black. pretty clean. FOR SALE!!!
Old Jun 26, 2001 | 08:24 PM
Bort62's Avatar
PLug the LIne, and Toss on a vented gas cap.
60 Ranchero - Project ( Money Hole )
85 Sport Coupe LG4 - Daily Driver 14.82 @ 91.1 (faster than Ed)
Reader's ride -> My Ride
Just another Hot Rod kid, or thats what they all tell me.
Livin' the Stereotype
Old Jun 27, 2001 | 07:04 AM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
This always perplexed me. It seems that there have been all sorts of horror stories about gas fumes, etc. I've got a piece of duct tape around the end of the tube and have never had a hint of gas odor, liquid or any other sort of problems.
The IROC Homepage
<A HREF="http://www.rit.edu/~jli4307/camaro" TARGET=_blank>
View the restoration of an 85 IROC</A>
"I didn't know a bored out Ford could go so slow" -Shenandoah
Old Jun 27, 2001 | 08:22 AM
Greg '85 T/A's Avatar
Car: 1985 Trans Am/WS6
Engine: 5.0 TPI
You still need to vent the tank! There should be a valve (small hockey puck looking thing) in-line between the hose to the tank and the inlet to the canister. There is a vacuum hose fitting on the valve. The vacuum connection regulates when the valve can open when the engine is running. When the engine is off, you will hear gurgling because positive pressure in the tank will force the valve open to vent (acts as a check valve - fumes only travel one way). At least retain this valve and its connection to vacuum so you don't vent the tank at the wrong time.
Old Jun 27, 2001 | 11:01 AM
1BadGTA's Avatar
Engine: 5.7 Liter
So the only reason I'd need to get a canister is for the safety factor right? Just so the gas fumes have some (safe) place to vent?
Old Jun 27, 2001 | 12:07 PM
Engine: 5.0 TPI
1BadGTA,
I've had mine out for a month now. It went bad and I had to wait for the part to come in. Just haven't had time to put the new one in. I redirected the vent hose down thru the bottom of the engine compartment. I've never seen any sign that gas comes out of it. I think the only issue here is keeping the vented gases away from an open flame - which shouldn't BE an issue, of course.
Old Jun 28, 2001 | 10:33 AM
1BadGTA's Avatar
Engine: 5.7 Liter
Does having the canister on the car have an effect on anything? i.e., performance. How about gas economy?
skinny z
Carburetors
Sep 29, 2015 11:25 PM
Racerx974
Sep 19, 2015 10:16 AM
TBRays98
Sep 6, 2015 05:05 PM
BurlyChev
Aug 16, 2015 09:08 PM
Mister_Johnny99
Interior Parts Wanted
Aug 14, 2015 12:59 PM
