engine hesitates when warm, runs fine when cold...
Old Jun 27, 2001 | 01:43 PM
spearson's Avatar
I have an 89 iroc with a rebuilt engine now 355.
When the engine is at operating temp and you slowly rev the engine up it is fine, but if you take a quick jab at the accelerator it will hesistate for a sec, then rev up. When the engine is cold, it runs fine except for the code 32 it shows me every morning. Brand new egr valve and solenoid and it still gives me that code?..
Anyone have any thoughts to share with me?
Steve
Btw, most of the engine sensors have been replaced, cts, iac, mat, knock, sensors in the head, tps... I think even the esc was replaced last year, not quite sure though.
Old Jun 27, 2001 | 05:51 PM
spearson's Avatar
anyone?
Old Jun 27, 2001 | 05:58 PM
Jason M 91Z's Avatar
Sounds like knock retard. Your engine is more apt to detonate at high temps. You may try a lower temp thermo like 180, and retard the timing a little.
-Jason M. 1991 Camaro Z28
Old Jun 28, 2001 | 01:10 AM
spearson's Avatar
It has a 180 stat in it, and the timing is at the stock setting of 6 degrees advance.
Old Jun 28, 2001 | 10:21 AM
Ed Maher's Avatar
Car: 04 GTO
Transmission: M12 T56
for the EGR code, MAF cars have a temperature sensor on the EGR valve itself. If you're getting a code 32 in the morning while you're still cold, either that or perhaps the EGR solenoid is bad. It isn't failing a functional test when the engine is cold, so it is failing a hardware test.
As to the hesitation when warm, you mention a 355, was this car always a 350. If not, perhaps your calibration is off enogh to give you trouble. My next guess either way would be your CTS is bad. I know you said you just replaced it, but getting a bad sensor out of the box is not uncommon. Other than that i can't think of anything else temp dependendent that would make a significant effect on driveability like that.
...ed
Ed Maher - Moderator @ The Carb Board
92 Z28 Convertible - Quasar blue / Tan top
LB9 4L60 GU2 G80 - stock, soon to be sleeper
-=ICON Motorsports=-
- Definitely prototypes, high powered mutants of some kind. Too weird to live, too cool to die
Old Jun 28, 2001 | 01:20 PM
spearson's Avatar
Now that i think of it, we soddered (sp?) the wire back into that sensor that screws into the egr valve, pretty sure that is the reason for the code 32.
The car was a 350 prior to this winter. Is there anyway to check the CTS with out a scanner?
theshackle
Mar 5, 2017 06:37 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
Kaweh
Aug 9, 2015 02:54 PM
Sherpajames
Aug 7, 2015 06:56 PM
