how to install the timing sprocket on the crankshaft ?
Old Jun 28, 2001 | 10:40 PM
james_fearn's Avatar
Is there a special tool that is need or a big hammer?
What is the best way?
James
Old Jun 28, 2001 | 11:06 PM
Steve91Z28 L98's Avatar
Car: 1991 Camaro Z28
I used a large socket (1 1/4" I think) that fit around the crank and up against the sprocket. Then I used the bolt the goes into the crank to tighten it down. It pushed the sprocket on easily.
Old Jun 29, 2001 | 03:48 AM
SS-84's Avatar
Car: 1992 RS
Transmission: 700R-4 when it works
easiest way to do it is to heat the gear.
I do not recomend using flame though.
I always put about 1 1/2" of water in an old pot, put the gear in the water, and boil for about 5 minutes. Season to taste. remove from water and install immiediately. It will go right on. No pounding and no pressing, no muss, no fuss.
Just don't use one of the old lady's good pots
LOBC-- SS-84
92 RS Heritage package with a 305
84 El camino
Old Jun 29, 2001 | 10:20 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
If you have a balancer puller & installer, you can use the installer tool to press it on along with the balancer, then pull the balancer back off.
ICON Motorsports
Vintageracer
Jan 10, 2020 05:33 PM
midge54
Dec 27, 2019 04:14 PM
383backinblack
Aug 15, 2015 06:36 PM
BBSDesigns
Aug 11, 2015 07:39 PM
89mulletbird
Southern California Area
Aug 10, 2015 10:16 AM
