For all 13 & 14 second cars with 700R4s....
I plan on taking my car to the strip as soon as I get some more miles on my rebuilt motor. I have a 700R4 transmission. I was wondering what gear you guys get up to in the quarter mile. Will it actually shift into 4th in a 13/14 second car, or do you cross the line in 3rd? Also, any guesses as to whether or not my car will see at least 13.99? Mods are listed in sig. ANY help is greatly appreciated. Thanks.
1984 Camaro Sport Coupe - 73K Miles, Rebuilt 355 TPI L98, Crane 2032 CompuCam - 214/220 @ .050", Crane adjustable fuel pressure regulator, MSD Blaster coil, custom burned PROM, stock TPI intake, Accel 24# injectors, gutted air box with K&N filters
F41 Suspension Package, 700R4 Tranny, TCI Breakaway torque converter, 3.27 Disc Brake Posi Rear
Hooker Shorty Headers, Catco High-Flow 3" Cat, Flowmaster 3" American Thunder Cat-Back
New Paint
Best 1/4 Mile Run (with old LG4 motor):
16.760 @ 80.74 MPH
Coming Soon:
Aluminum Drive Shaft
New Paint
16.760 @ 80.74 MPH
Coming Soon:
You should be able to net some sub 14's with the 350 if it's built right and since you have 3.27 gears, you will have no problem holding 3rd gear in the 1/4 mile.
I have 4.10 gears and I'm right at redline when I cross over the finish line in 3rd.
1990 GTA
-355 carb'd, nicely reworked '64 vette heads, 2500 stall, 4.10's, other small things.
-Alston SFC's, Eibach Pro-kit, Koni's all around
-100+ nitrous shot
-Cruising in style with leather and nice stereo.
1990 GTA
-100+ nitrous shot
Your 700R4 will not shift into 4th. Even on an open desert road. It's built not to, you can change that by modding it with an upshift sleeve kit. But you wouldn't want to on the strip anyway, that 4th gear is you overdrive and you don't use it in racing. And unless you have very tall rear gears you won't get the need for 4th gear anyways..
I almost trap In 2nd, actually.
I cross at 4 grand in 3rd after shifting out of 2nd at 6.
Think I need Gears ?
60 Ranchero - Project ( Money Hole )
85 Sport Coupe LG4 - Daily Driver 14.82 @ 91.1 (faster than Ed)
Reader's ride -> My Ride
Just another Hot Rod kid, or thats what they all tell me.
Livin' the Stereotype
Car: 2018 Camaro SS
Engine: LT1 w/Paxton 1500SL
u won't need to hit OD at the track...i have the same rear as u and i cross the line at like 4K maybe a bit higher...
Originating member of the SJNEP Crew
Vice President of the Jersey Fbody Crew(JFA)
Check out MyGTA Nicknamed:The Big Red Machine
***AOL IM RiceEatinGTA***
Moderator at www.transamgta.com
"What does not kill us only makes us stronger"
Tony
Tony
Car: '89 GTA
Engine: ZZ6TPI
If you are ending in overdrive, you have the wrong rear end gears. You always want to end at the top of your 1:1 gear, which would be 3rd in the 700r4. I am at about 4000 in 3rd when I cross the line.
89 Transam GTA, 350TPI, auto, 3.27 rear, dual cats, gray.
Magnaflow cat-back,
K&N open element,
Best E.T. 14.63@95mph
Magnaflow cat-back,
K&N open element,
I would say that if you have the whole cared tuned up well, you should have no problem getting into the 13's. As for your tranny question, these guys are somewhat right IMO. For you, you should not get through 3rd, but your tranmission will shift into 4th at some point. To my knowledge, with using about 5 of these cars with 700's, the whole shifting into 4th thing is a little bit of a falicy. It seems some cars do and some cars don't, but it is more often than not how you have the kickdown cable adjusted. If you are moving along and you step down your car might do into 3rd and not come back into 4th but if you are steadly accelerating it certainly will. How do you think all these people can go over 125. Your trans and gears, assuming a normal tire, will top out at 128 in 3rd gear. So you would probably be running low 11's high 10's to get that. My suggestion is you should get yourself some sort of shift kit and a rachet shifter. Not only is it more fun to drive, but you will get faster ets, and prolonged tranny life, typically. Good luck.
When I had 2.73 a could pull all the way to the line in second at about 100 MPH. Not sure where I will be with the 3.42s but hoping it will be around 4000 for the reasons stated above.
bsa
"If they do not run, Then they will die." - Stonewall Jackson
'87 IROC, 355 TPI, Converted to SD, 700R4, B&M Megashifter, 3.42, Trick Flow Twisted Wedge Heads, Edelbrock Intake, Accel Runners, Comp Cam, Crane Gold rockers, Lucas 24# injectors, Edelbrock headers, Flowmaster 3'' exhaust, Mallory Ignition, Transgo Performance Shift Kit, Corvette Servo, 2,000 Stall Torque Converter
bsa
Car: 1991 Camaro Z28
Axle/Gears: Strange 12 Bolt, 3.42
My car runs in the mid 13 sec range. I end the 1/4 mile in 3rd gear at about 5200rpms with 4.10 gears.
best 1/4 mile so far: 13.4 @ 101mph
84 Camaro 305 ported & milled heads, 3 angle valve job, Edelbrock Performer RPM intake, Hedman full length headers, Accell ignition, Crane 274H cam, B&M 700R-4, 3000 stall speed, 4.10 gear,
M/T ET street tires
visit my website at http://www.geocities.com/jbenge/page1.html
M/T ET street tires
Linson
Aug 21, 2015 02:12 PM
