How do I tell if computer is bad?
Old Jun 28, 2001 | 09:42 AM
Brian Felts's Avatar
Car: 89 RS 355/ 89 IROC Convert
Engine: Hot Cam 355/TPI 305
Transmission: All 700r4's
How do I tell if my computer is bad. I don't have a scan tool but I did try the pin in the ALDL port and the SES light just stays on.
Brian
1989 Camaro RS
305 .030 over Hydro Pistons
Vortech heads milled to 58cc...Performer RPM intake....LT4 cam..Crane Gold rockers...FastChip custom chip...ALum. Driveshaft...3.73 gears with Posi...underdrive pullys...Rebuilt 700R4 with Vette Servo and B&M shift Kit...MSD ignition...A/C Delete No SMOG junk....1997 SS leather interior...B&M Shifter... Ultimate TBI mods...14X3 K&N open Element Non-Drop...Hooker headers....3" exhaust with Flowmaster Cross flow 16X8 Wheels from 97 RS Spohn LCA's Spohn Panhard Bar..LETS PLAY FORD!!
www.geocities.com/feltsb
Old Jun 28, 2001 | 10:11 AM
Nightcruzer's Avatar
Car: Trans Am
You need to check the ALDL with the car not running. Just making sure you did that. Jump the A B terminals and turn the ignition key on (where dash lights come on) but DO NOT START THE CAR WITH ALDL JUMPED!!. This will cause damage to the computer. So if you do this and don't get a code 12 three times (one flash followed by two flashes) then the computer is not going into diagnostic mode and is probably shot.
Old Jun 28, 2001 | 04:46 PM
WHen you say AB terminals what number does that equal out to. I only find then numbered.
Brian
1989 Camaro RS
Old Jun 28, 2001 | 10:49 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
Top two on the right
XXXXXBA
XXXXXXX
Old Jun 29, 2001 | 03:52 PM
Yes I have done those and the SES light is on and stays on. There is no blink at all and it will not go off.
What do ya think
Brian
1989 Camaro RS
Old Jun 29, 2001 | 09:18 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
Just to verify the process..
Turn key to "run", do not start the car.
Jump the A and B connection.
Is this the way you're doing it?
Old Jun 29, 2001 | 09:47 PM
Yes I am afraid that is the way I am doing it. THanks for the help what do you all think. My air/fuel mix is off....my timing is off.......and it will not idle...
Thanks For putting up with my problems.
Brian
1989 Camaro RS
Old Jun 29, 2001 | 10:08 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
Well, first I'd check a few things...
Make sure the EPROM is in correctly and no pins are bent under...i recall you saying you have a Hypertech one in there?
If the above checks out okay, put the stock EPROM back in, just to eliminate the chip as the problem.
About the only other thing I could suggest is to make sure all the ECM grounds are intact and connected to bare metal on the heads, and not freshly painted metal.
F.I. 57 Belair
Aug 23, 2021 01:09 AM
92firebirdguy
Sep 1, 2016 07:53 AM
Johnoooooo
Sep 22, 2015 08:55 AM
89-91fun
South West Region
Sep 12, 2015 03:06 PM
Stryker412
Sep 7, 2015 09:11 AM
