Car throwing Code 44, Can't figure it out...
Car: 1998 Trans Am WS6
Transmission: M6
My car keeps throwing the code 44. It means "ECM is detecting lean exhaust from the O2 sensor for extended period of time". I replaced the O2 sensor and the MAF sensor already, along with recharging my K&N air filters. The biggest problem is that when I am stopped the car goes into a real rough idle and the service engine light comes on. But if I am goin it usually rides fine. What could the problem be?
Also, does anyone know of a really good 3rd gen mechanic in the Lowell area?
-Scott
-Scott
Car: 1989 Iroc-Z
Engine: 5.7L TPI
What else have you checked on it. How about fuel pressure, MAF sensor, vacuum leaks, bad fuel, or an exhaust leak? Just a couple of thoughts!!!
db057
Aug 11, 2015 10:11 PM
rsrmoore
Aug 7, 2015 08:44 PM
