can you have a bad O2 sensor and no codes?
Old Jun 28, 2001 | 11:51 PM
302GT_killer's Avatar
is this possible?
Old Jun 28, 2001 | 11:52 PM
Omar's Avatar
I think it is possible, but I could be wrong.
1989 IROC-Z 5.7L
NOS 150HP kit
ProBuilt 700R4, PI Vigilante 2800 stall lockup
Baer Brakes 12" Sport System
Old Jun 28, 2001 | 11:54 PM
firbird's Avatar
how often are u recomended to change it any ways?
Guest
Guest
Posts: n/a
Entirely possible... our computers are mostly stupid unfortunately.
Old Jun 29, 2001 | 12:10 AM
i know youre supposed to change it every 30000 miles, and i had the cat replaced a little over a year ago, and shortly thereafter, it slowly began to run like crap and run crappier as time wore on, and i know they didnt change the sensor but im thinking they mightve screwed it up taking it out or putting it back in...hmmmm....the car runs real lean too...
Old Jun 29, 2001 | 08:08 AM
irocbsa's Avatar
YES, change that thing. A lean condition is a good indicator of an O2 on its way out. I had a CTS problem for a LONG time and the computer didn't show a code fr a few months. It was driving me insane.
bsa
"If they do not run, Then they will die." - Stonewall Jackson
'87 IROC, 355 TPI, Converted to SD, 700R4, B&M Megashifter, 3.42, Trick Flow Twisted Wedge Heads, Edelbrock Intake, Accel Runners, Comp Cam, Crane Gold rockers, Lucas 24# injectors, Edelbrock headers, Flowmaster 3'' exhaust, Mallory Ignition, Transgo Performance Shift Kit, Corvette Servo, 2,000 Stall Torque Converter
Old Jun 29, 2001 | 10:23 AM
Conv389drv's Avatar
The O2 sensor is probably dirty. It can't "see" any oxygen in the exhaust, so the computer interprets this as a rich condition, and tries to compensate by making the car run lean.
Old Jun 29, 2001 | 10:38 AM
Grim Reaper's Avatar
Car: Death Mobile
Engine: 666 c.i.
Often, sensors become "weak" rather than flat-out fail. When they become weak, they will not trigger a code, but they give weird results. This is where a scan tool becomes useful. After you have done enough scans of the motor, you begin to recognize normal operation. When you notice the results seem to get out of the norm, you know that you have to start looking at something.
But remember, just because one sensor is giving you unusual numbers, does not mean the sensor itself is at fault. Often, another part that is "going out of spec" may cause another sensor to give unusual numbers as the "system" is attempting to compensate. It is a "system", which means "all parts working in unison".
Old Jun 29, 2001 | 11:06 AM
jobryan26's Avatar
I don't think my O2 sensor has ever been changed. And it has 155,000 miles. Guess I better change it huh?
Trans Am:
(Engine)305 TPI
180 Degree Thermostat
JET Fan Switch
TB Bypass
Accel 300+ 8.8 Racing Wires
Accel Super Coil
Bosch Platinium Plugs
Custom Ram Air with K&N
Removed Emissions Equipment & Cat.
(Stereo)Full Kenwood Excelon System
See my Ride:
https://www.thirdgen.org/rides/index...ew&rideid=1324
Member at kyfbodies.org
Old Jun 29, 2001 | 01:19 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
Never mind
[This message has been edited by 8Mike9 (edited June 29, 2001).]
Old Jun 29, 2001 | 09:43 PM
got under the car and looked at it today-man that thing is crusty
Old Jun 30, 2001 | 10:34 AM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
Glenn has the right idea, but I refer to them as "lazy". They don't switch as often or as fast as they should, and therefore the engine cannot repond to changes like it should. Also over time, they become degraded and loose effectiveness. Unfortunatly, like mentioned before, our computers are not setup to be able to detect this, and therefore it is recomended to change it every 15-30K
If you live in Southeastern US, check us out!
South East Thirdgen
GM Master Tech
ASE Master Tech + L1
Savannah, GA
'87 Trans Am
S/D TPI retrofit including functional PassKey,
22# injectors,
Whatever chip I feel like burning,
JET AFPR, Ported Plenum,
TB Coolant Bypass, Custom Cold Air,
SSM SFC, KYB Shocks, Boxed LCAs, Wonder Bar,
8mm Accel wires,
Flowmaster Exhaust,
16" GTA rims,
Corvette Servo,
3.73 Posi
4wheel Disc Brakes
Summit 1-5/8" headers, 2.5" Dynomax catback.
Best 1/8: 9.519@72.74
'97 Bonneville SSE
Old Jun 30, 2001 | 12:44 PM
DartByU's Avatar
Car: 92 Camaro RS
Engine: 305 TBI
<font face="Verdana, Arial" size="2">Originally posted by Conv389drv:
The O2 sensor is probably dirty. It can't "see" any oxygen in the exhaust, so the computer interprets this as a rich condition, and tries to compensate by making the car run lean. </font>
If a dirty O2 senser causes a lean condition then what will cause a rich condition? At about 70,000 miles my gas mileage went from 20 MPG to about 15 MPG and I had black smoke coming from the exhaust, I changed the O2 senser and that fixed it.
92 Camaro RS 5.0 5-Speed(Quasar Blue)
14" Open Air Cleaner
3.08 Posi-trac
Edelbrock TBI Intake
Crane cam
Ported & polished stock heads 3 angle valve job
HyperTech Chip
SLP Headers (Ceramic Coated)
UltraFlo cat-back exhaust
74 Dodge Dart Sport 360 (11.2 1/4 mile)
2000 Dodge 1500 Ram Sport
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
Falcon50
Aug 22, 2020 03:26 PM
db057
Jan 10, 2020 08:55 PM
92firebirdguy
Sep 1, 2016 07:53 AM
racereese
Oct 3, 2015 03:46 PM
