check engine light
Old Feb 15, 2005 | 11:04 PM
BCdawg57's Avatar
Car: '91 Z28, '13 Civic EX-L
Engine: 355 LT1, 1.8 I4
Transmission: T56, 5spd auto
Axle/Gears: 10 bolt 3.42(as long as no breaky)
check engine light
ocasionaly when im driving my service engine soon light comes on. I have no idea why. It only happens every once in a while and if i turn the car off, and start it again, its gone. if u take a screwdriver or somthing metal and put it on either of the fuel rails, and put your ear up to it, you can hear a ticking, kinda fast paced, i dont know if this is normal or if somthing is going wrong, i dont know if that could be it or the fact that my cats are rustin out...any info/help would be apreciated
thanks
Old Feb 16, 2005 | 12:53 AM
Dynodan's Avatar
Car: 1992 firebird
Engine: 305tbi
Do a search on how to find what code is popping up with your check engine light also whens the last time your oxygen sensor was replaced. Find your code first . The code will give you the area that the problem is in
Dynodan
Old Feb 16, 2005 | 01:50 PM
BCdawg57's Avatar
will that code reading thing work if the light isnt on constantly?
Old Feb 16, 2005 | 02:09 PM
phess11's Avatar
Car: 83 Z28
Engine: 305 (LG4)
Transmission: THM700R4
Axle/Gears: 10 bolt, 3.23 non-LS
yes, the codes are stored for a long time, unless the battery is disconnected.
Wade787b
Sep 29, 2015 01:15 PM
Jae992
Aug 27, 2015 09:07 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
Omega
Aug 10, 2015 12:46 PM
