gas hog 3=4 mpg help!
Car: 89 formulas
Engine: Have 2 5.7s and 1 formula 5.0
Transmission: auto
My wife drives our 5.0 formula and compained about mileage. I have 2 formula 350s that I drive . I drove hers and at 25 miles It used half a tank. It runs well but smells of gas and shows drippage back by the tank. I replaced o2 sensor and fuel pressure regulator no differance. Plugs don't show excessive carbon . Where is the gas going? Help! thanks for any input,Dave
Car: "02 z-28
Engine: LS-1
It's a closed system. If you have gas dripping better get it fixed, thats where the fuel is going-on the ground- not into the engine. Most likely a leak in a line or at the fuel filter. If you dumped that much fuel into the engine it would flat out not run.
Car: 4
Engine: 6
Transmission: 5
Sounds like you might have a broken fuel filler neck.
There's a recall for that on some of these cars; I don't know offhand what years and models, but yours might be one of them. Check the government's database of recalls and see if you're eligible for a new gas tank under warranty.
Otherwise, it's probably one of the pieces of rubber line that hook the tank's metal lines to the car's metal lines.
Car: 89 formulas
Transmission: auto
4mpg
Thanks, got the car on alift and found small puncture above the heat shield. Fuel would evaporate off the heat shield and never leave more than a few drops at most on the ground. lucky it never caught fire! Thanks Dave
