cruise control ??
Old Jul 1, 2001 | 09:10 AM
87firebird's Avatar
cruise control ??
HI, whenever I use my cruise control it never stays at the same speed. It slows down a couple miles and then it speeds up a couple miles. It's very annoying. Is there any way to fix it so it stays at the same speed??
Old Jul 1, 2001 | 09:38 AM
Vader's Avatar
87,
Make certain the throttle linkage, speedo cables, and cruise throttle cable are clean and lubricated. If you open the top of the cruise unit, make sure the "shoelace" is not twisted and is tightly wound on the thimble.
Later,
Vader
"Let the bodies hit the floor!"
Adobe Acrobat Reader
Old Jul 1, 2001 | 09:43 AM
Vader's Avatar
OOPS! You have the vacuum servo on your '87, not the digital unit. My bad!
Forget about the shoelace. You should still check the cables, vacuum hoses, and can adjust the cable by selecting one of the holes in the cable bracket at the cruise unit that allows the least amount of slack (you must have a little slack in the cable).
You probably have some mechanical binding or sticking, not an electronic problem.
Later,
Vader
junior419
Apr 7, 2025 11:35 AM
wigmobile
Feb 26, 2025 02:56 PM
DiabloWS6
Southern California Area
Feb 15, 2016 02:08 AM
DiabloWS6
20
Dec 11, 2015 04:12 PM
scottmoyer
Sep 7, 2015 07:06 PM
