Car wont run right!
Old Feb 16, 2005 | 12:35 PM
superdave396's Avatar
Car: 86 Iroc Z
Transmission: .....auto
Car wont run right!
this just happened out of no where. about a week ago i went to get in my car and go to school. i started it and it turned over but wouldnt stay running. i can give it all the gas i want and it will run but as soon as i stop giving it gas the damn thing dies. i have a couple of ideas in my head but im probably wrong so does anybody have any idea of what the problem could be?
Old Feb 16, 2005 | 05:06 PM
Vader's Avatar
TPI?
IAC.
Old Feb 16, 2005 | 05:39 PM
Car: 86 Iroc Z
it is a TPI. IAC?
Old Feb 16, 2005 | 05:59 PM
razor's Avatar
Car: 1992 GTA
Axle/Gears: 4.10
Do you have any stored codes in the ECM??? My best guess is to unplug the MAF while the car is off. Then try to start it. If it fires up and runs do a search for code 33 and code 36 and figure out the location of your MAF relays. Test relays before replacing the MAF as they are way cheaper to replace.
EDIT: IAC is the idle air control valve in your throttle body. Do a search for it as well as Vader and you should find some pretty awsome info that he has posted on this.
Old Feb 16, 2005 | 09:22 PM
Car: 86 Iroc Z
i will try that in the morning and then let you know what happens. thanks.
Old Feb 17, 2005 | 02:01 PM
vernw's Avatar
Car: 91 Formula WS6 (Black, T-Tops)
Engine: 383 MiniRam (529 HP, 519 TQ - DD2K)
Transmission: Built '97 T56, Pro 5.0, CF-DF
Axle/Gears: 4.11 posi Ford 9"
I wouldn't rule out the fuel filter, either.
Old Feb 17, 2005 | 02:23 PM
Car: 86 Iroc Z
I unpluged the MAF and nothing changed. how do i know if i have any codes stored in the ECM?
Old Feb 17, 2005 | 04:10 PM
Vader's Avatar
Check the Tech Articles at the front page of the site. There are instructions for retrieving error codes.
As long as you are searching for information, perform a search for "IAC cleaning" and see what is displayed.
midge54
Dec 27, 2019 04:14 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
kyleb24
Aug 15, 2015 08:24 AM
1992 Trans Am
Aug 8, 2015 08:16 PM
