Are these holes supposed to be here? Intake manifold question
Old Feb 16, 2005 | 03:00 PM
Nate86's Avatar
Car: 1999 Saturn SL2
Engine: 4 cylinder
Transmission: 4-speed automatic
I recently bought a ZZ4 intake manifold for $150. It wasn't until my friend took a look at it that I realized a few holes inside the intake manifold where it looks like they should not be. However, I thought I'd post a pic here to confirm this.
What should I do if these holes shouldn't be there? Is there any way to patch them so I can use the manifold, which is otherwise brand new and in perfect condition?
Attached Thumbnails Are these holes supposed to be here? Intake manifold question-c-documents-settings-administrator
Old Feb 16, 2005 | 03:12 PM
Lo-tec's Avatar
Car: clapped out 84Z
Engine: 355 efi roller
Transmission: tremec TKO
I believe they are for EGR. JB weld will take care of them. Might want to look at EGR system because if blocked off will probably not make a difference.
Old Feb 16, 2005 | 03:30 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
That is correct; they connect to the EGR valve passages.
Old Feb 16, 2005 | 03:57 PM
Nate86's Avatar
Engine: 4 cylinder
So let me just make sure I completely understand... these holes are correctly placed where they are? I am planning on keeping my EGR valve functioning. So I guess they are needed for some kind of temperature-related function of the EGR valve? The holes look like they go into a coolant passage.
Old Feb 16, 2005 | 04:25 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
If you put an air hose onto the EGR mount you will feel air going through those holes. Those passages allow exhaust gasses to recirculate into the combustion cycle.
Old Feb 16, 2005 | 04:27 PM
pasky's Avatar
Car: 1991 RS Camaro (Jet Black)
Engine: 95 383 CI (6.3) LT1
Transmission: 95 T-56
Cap them, why would you want hot carbon filled air into your exhaust manifold? Stupid system....
Old Feb 16, 2005 | 04:31 PM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Because it improves your mileage, reduces emissions, reduces combustion temps and shuts off during WOT. EGR may be ugly to look at but it does serve a very important purpose.
Old Feb 16, 2005 | 04:37 PM
pasky's Avatar
I understand the system shifty. Im just saying, the man will be running a carb anyways. All that carbon build up can't be good. I'd cap it. I think if he was worried about milage he'd go fuel injected.
Old Feb 16, 2005 | 05:46 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Yeah, everyone who worries about mileage can afford to convert to fuel injection.
Old Feb 16, 2005 | 06:04 PM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
I gottcha. Whatever he chooses won't hurt him either way.
Old Feb 16, 2005 | 08:01 PM
Nate86's Avatar
Engine: 4 cylinder
I'll probably end up keeping it to keep the ECM happy. Gonna retain the stock CC QJet with a few tuning modifications.
Old Feb 17, 2005 | 07:06 AM
Lo-tec's Avatar
Been there, done it. ECM will be just as happy without it.
Jake_92RS
Jan 28, 2020 10:37 PM
Zeek1041
Theoretical and Street Racing
Aug 21, 2015 08:45 PM
86IROC112
Aug 17, 2015 02:00 PM
st.evel07
Aug 13, 2015 06:15 PM
Jake_92RS
Aug 11, 2015 10:39 AM
