350 won't fire up(?)
Old Jul 1, 2001 | 08:36 PM
MTCAMARO's Avatar
Car: Camaro sc
Engine: 350 cid.
Just spent 2 weeks building up this 350 4-bolt and finally got it in the car today.Went to fire it up,and she's backfiring through the carb like it's out of time or something.Took the cap off and the rotor is pointing at number 1 terminal just like it's supposed to,with the timing mark on 8 degrees.Do you guys think maybe i'm not on the compression stroke for the #1 cylinder?Can i just pull the distributor,do a full revolution of the motor,and drop the distributor back in to correct this?Or will it make no difference.Any suggestions would be much appreciated.
Old Jul 1, 2001 | 09:30 PM
Enkil's Avatar
Does sound like the distrib might be 180* off...
You could turn the engine once, or if I'm not mistaken, just flip the rotor around 180 degrees.
89 iroc-z 305 tbi
k&n filtercharger, open element air filter. nuffin' else
1992rs/ss
Jan 31, 2025 05:10 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
Eric-86sc
Aug 24, 2015 09:01 PM
justin57
Aug 20, 2015 07:05 PM
djmarch
Aug 19, 2015 12:07 PM
