How hard is it to change a rear axle?
Old Jun 29, 2001 | 03:30 PM
89bonestockiroc's Avatar
HI , I am about to buy a 10 bolt rear end with posi and disc brakes form a 90 firebird.
I am replacing a 9bolt on my 89 iroc.
How hard is it to remove the old 9 bolt and install the 10 bolt? I have never tried messing with a rear axle before so i have no idea.
Thanks,
Mike
Old Jun 29, 2001 | 07:26 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
It's not too bad, except that it's heavy, and the bolts have a tendency to be a PITA. Although, if yo're lucky your car has never been in a place where they salt the roads, so they won't be rusted in place quite so bad. Other than that, it's not bad at all. You might want to change out your springs and shocks at the same time since it's no more work whatsoever to do the springs (they'll fall out during the process) and the shocks are only about 10 more minutes. Get the Moog replacement spings and the white Monroe shocks, they will really make the car ride and drive better.
ICON Motorsports
Old Jun 29, 2001 | 09:14 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
Hey Bonestock, give me a holler if you're going to go woth the 10bolt, I'd be interested in your 9 bolt, maybe we can make a deal with me swapping the rearend for you?
Old Jun 29, 2001 | 09:21 PM
Rob P's Avatar
Car: 89RSconvtZZ4TPI
Engine: ZZ4TPI
Transmission: 700R4 TRIPP TRANNY
Swapping the rear is just a wrenching a little and keeping the rear balanced on the jack. Axles take a little more with the c-clips.
Which are you doing?
Rob P
89RSconvtZZ4TPI Edelbrock Intake
SLP Dual Cold Air Intake 1 5/8" Headers Semi-Siamesed Runners, IROC
suspension, alum shaft. Numerous mods.
92Z28convt5spd (stock)
71Impala convt 402BB
BETTER DRIVING THRU SUPERIOR HORSEPOWER!
Old Jun 30, 2001 | 02:25 AM
BigChevy342's Avatar
All i can say is air tools, if you got an impact and some sockets, its a breeze, just make sure you soak the bolts with some type of a lubricant so the bolts won't break so easy (if they do) it will save a lot of cussing and breaking crap
Old Jun 30, 2001 | 10:29 AM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
Rearend Swap
The hardest part will be like the other mentioned, breaking the bolts free. You will also need to find something to lift the rear.
If you live in Southeastern US, check us out!
South East Thirdgen
GM Master Tech
ASE Master Tech + L1
Savannah, GA
'87 Trans Am
S/D TPI retrofit including functional PassKey,
22# injectors,
Whatever chip I feel like burning,
JET AFPR, Ported Plenum,
TB Coolant Bypass, Custom Cold Air,
SSM SFC, KYB Shocks, Boxed LCAs, Wonder Bar,
8mm Accel wires,
Flowmaster Exhaust,
16" GTA rims,
Corvette Servo,
3.73 Posi
4wheel Disc Brakes
Summit 1-5/8" headers, 2.5" Dynomax catback.
Best 1/8: 9.519@72.74
'97 Bonneville SSE
[This message has been edited by GMTech (edited June 30, 2001).]
Old Jun 30, 2001 | 10:37 PM
GMTech,
Thank you very much for that link. I think it will make me much more comfortable doing this swap. I do have one question though, the 10 bolt that I am putting on there to replace my 9bolt is from a 90 firebird and has posi and rear disc brakes but I dont know if the calipers are aluminum or iron. Does it even make any difference?
Thanks,
Mike
Old Jul 1, 2001 | 12:05 PM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
They are probably aluminum, but your best bet is to get e-brake cables for the '90 firebird. There are three cables total, you only need both rear.
South East Thirdgen
GM Master Tech
Savannah, GA
'87 Trans Am
22# injectors,
8mm Accel wires,
Flowmaster Exhaust,
16" GTA rims,
Corvette Servo,
3.73 Posi
4wheel Disc Brakes
'97 Bonneville SSE
Old Jul 2, 2001 | 09:31 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
The axle swap itself is cake; however, doing the brakes (hookups, cables, bleeding the lines) might drive you mad.
-Tom P (Hot rodded 1986 Firebird 2.8l) from http://www.f-body.net/mailbag/3rd/3rd_mailbag.html message boards
---Think your car could be pic of the week? Visit http://www.f-body.net for details!
customblackbird
Aug 15, 2021 10:16 PM
maroe624
Apr 16, 2017 08:29 AM
draco
Oct 4, 2015 09:25 PM
E Rod
Aug 28, 2015 05:17 AM
